[gdal-dev] PostGIS Out of db VRT containing JPEG2000 GDAL 2.1 OpenJPEG
bboughton
bboughton at gmail.com
Sat Jun 4 03:44:31 PDT 2016
Thanks for your suggestions.
SELECT short_name FROM ST_GDALDrivers();
Lists VRT, GTiff, JPEG2000 etc as a supported formats
I am able to use gdal_translate to convert between VRT (created using
Sentinel2 Driver) and GeoTiff
One thing I do remember now - could be a question for PostGIS list - when
building PostGIS I didn't use the latest version of Geos (v3.4 instead of
3.5 as 3.5 was not available as package). According to this
(https://lists.osgeo.org/pipermail/postgis-devel/2015-May/024878.html) post
I don't think it would affect this issue.
View this message in context: http://osgeo-org.1560.x6.nabble.com/PostGIS-Out-of-db-VRT-containing-JPEG2000-GDAL-2-1-OpenJPEG-tp5269888p5269922.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
