[gdal-dev] PostGIS Out of db VRT containing JPEG2000 GDAL 2.1 OpenJPEG
Jukka Rahkonen
jukka.rahkonen at maanmittauslaitos.fi
Sun Jun 5 02:00:12 PDT 2016
bboughton <bboughton <at> gmail.com> writes:
> Thanks for your suggestions.
> SELECT short_name FROM ST_GDALDrivers();
> Lists VRT, GTiff, JPEG2000 etc as a supported formats
Driver JPEG2000 means the Jasper driver which is rather useless for
geospatial images http://www.gdal.org/frmt_jpeg2000.html. Do you see also
driver JP2OpenJPEG listed http://www.gdal.org/frmt_jp2openjpeg.html?
-Jukka Rahkonen-
