[gdal-dev] New driver implementation with larger block size
Javier Calzado francisco.javier.calzado at ericsson.com
Tue Jun 7 00:01:20 PDT 2016
Thanks for your answer Even,
I knew about GDAL_ONE_BIG_READ, but given that our tool will access
several raster simultaneously and will perform intensive operations with
them, I like the idea of allowing GDAL caching blocks, as long as cache
hits rate is high, this will increase performance I guess. GDAL cache is
pretty smart and well done, this way we avoid re-implementing our own
custom cache system. Besides that, we will do intensive access to raster
on a pixel basis, and it seems that performance, according to some tests I
did, is highly improved using direct block pointers (GetLockedBlockRef)
over RasterIO pixel access. So, unless I am missing something with
RasterIO, I think we will go for the cached block access method.
So, I guess the only way to accomplish larger block sizes in my new driver
is to implement a custom rasterband derived from GDALRasterBand and
implement IReadBlock/IWriteBlock methods, right?
My concern in that case is ... what would happen with blocks that cannot
be completely filled with raster data? I mean, given a 150x150px raster
for example, if a define block size as 150x100, the second block will have
the last 50 scanlines empty, does GDAL internally handle this situation
properly?
