[gdal-dev] New driver implementation with larger block size
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Tue Jun 7 00:54:04 PDT 2016
Javier Calzado <francisco.javier.calzado <at> ericsson.com> writes:
> Thanks for your answer Even,
> I knew about GDAL_ONE_BIG_READ, but given that our tool will access
> several raster simultaneously and will perform intensive operations with
> them, I like the idea of allowing GDAL caching blocks, as long as cache
> hits rate is high, this will increase performance I guess. GDAL cache is
> pretty smart and well done, this way we avoid re-implementing our own
> custom cache system. Besides that, we will do intensive access to raster
> on a pixel basis, and it seems that performance, according to some tests I
> did, is highly improved using direct block pointers (GetLockedBlockRef)
> over RasterIO pixel access. So, unless I am missing something with
> RasterIO, I think we will go for the cached block access method.
> So, I guess the only way to accomplish larger block sizes in my new driver
> is to implement a custom rasterband derived from GDALRasterBand and
> implement IReadBlock/IWriteBlock methods, right?
> My concern in that case is ... what would happen with blocks that cannot
> be completely filled with raster data? I mean, given a 150x150px raster
> for example, if a define block size as 150x100, the second block will have
> the last 50 scanlines empty, does GDAL internally handle this situation
> properly?
Unfortunately I do not really understand what you are talking about but when
I saw words "blocks" and "caching" I started to think that the same words
appear in Ari Jolma's raster algebra
https://trac.osgeo.org/gdal/wiki/rfc62_raster_algebra
Could there be some overlaps?
-Jukka Rahkonen-
