[gdal-dev] Problem using ogrlineref
Dmitry Baryshnikov bishop.dev at gmail.com
Tue Jun 7 07:16:26 PDT 2016
Hi Nicola,
The idea of ogrlineref was follow:
1. You have layer with some lines and some reper points with known
linear coordinates
2. The reper points divide lines on equal parts (e.i. 1000 m) - this is
important that parts should be equal
3. The result file will have special structure (required fields: beg,
end, scale, and some optional)
4. During referencing  ogrlineref make attribute query and get needed
part based on beg and end fields (which is rather fast), and than calc
point position inside this part.
In your case, the simple way is to extract begin and end point of your
lines and make them reper points. After that all steps are usual.
There is no sense to move other fields into the parts file from your
original datasource. But you can use -lf option to store some value and
use it in future for join with your original data.
Best regards,
     Dmitry
07.06.2016 15:19, Nicola Baraldo (ICONSULTING) пишет:
> Hi guys,
> I am trying to split some routes into segments of the same length
> (dynamic segmentation) using ogrlineref command.
> My data is stored in a shapefile containing a set of paths, for each
> path I know the length in meters.
> I have tried ogrlineref with –create, –get_coord and - get_subline.
> For the first option I don’t have a reper datasource to provide
> because I don’t have mile-stones, are they really necessaries?
> The second and third options give me the following error for each path
> contained in the input shapefile; with –get_coord I have tried both
> options “–m 0” and “–m 1000”, with –get_subline I have tried “-mb 0
> -me 1” options.
> Can someone help me using this command? Is there a better way to
> perform dynamic segmentation using GDAL?
> Moreover my shapefile contains also a lot of other fields, there is a
> way to keep these information also in the output file?
> Thanks,
> Nicola
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160607/4821150a/attachment.html>
