[gdal-dev] Not able to build GDAL on RHEL_5 64 bit?
Andrew C Aitchison
andrew at aitchison.me.uk
Wed Jun 22 22:07:06 PDT 2016
On Wed, 22 Jun 2016, sablok wrote:
> I am trying to compile gdal-2.0.2 from source using this tarball
> https://trac.osgeo.org/gdal/wiki/DownloadSource I have tried to navigate
> through every conceivable error on this mailing list archive to resolve the
> issues I have encountered while compiling it from source. The set of
> commands I am using to compile it are as follows -:
> /export GDAL_BUILD_VERSION=2.0.2
> cd ${path}/config/gdal/gdal-$GDAL_BUILD_VERSION && ./configure
> --prefix=${build_root} --without-xml2
> cd ${path}/config/gdal/gdal-$GDAL_BUILD_VERSION && make clean
> cd ${path}/config/gdal/gdal-$GDAL_BUILD_VERSION && make install/
> and this keeps on failing with the following error -:
> /config/gdal/gdal-2.0.2/.libs/libgdal.so: undefined reference to `sqlite3_create_module_v2'
> config/gdal/gdal-2.0.2/.libs/libgdal.so: undefined reference to `sqlite3_malloc'
> config/gdal/gdal-2.0.2/.libs/libgdal.so: undefined reference to `sqlite3_vfs_register'
> config/gdal/gdal-2.0.2/.libs/libgdal.so: undefined reference to `sqlite3_prepare_v2'
> config/gdal/gdal-2.0.2/.libs/libgdal.so: undefined reference to `sqlite3_realloc'
> config/gdal/gdal-2.0.2/.libs/libgdal.so: undefined reference to `sqlite3_open_v2'
> config/gdal/gdal-2.0.2/.libs/libgdal.so: undefined reference to `sqlite3_declare_vtab'
> config/gdal/gdal-2.0.2/.libs/libgdal.so: undefined reference to `sqlite3_vfs_unregister'
> config/gdal/gdal-2.0.2/.libs/libgdal.so: undefined reference to `sqlite3_vfs_find'
> config/gdal/gdal-2.0.2/.libs/libgdal.so: undefined reference to `sqlite3_auto_extension'
> config/gdal/gdal-2.0.2/.libs/libgdal.so: undefined reference to `sqlite3_create_module'
> config/gdal/gdal-2.0.2/.libs/libgdal.so: undefined reference to `sqlite3_clear_bindings'
> collect2: ld returned 1 exit status
> make[1]: *** [gdalinfo] Error 1
> make[1]: Leaving directory `config/gdal/gdal-2.0.2/apps'
> make: *** [apps-target] Error 2/
The version (3.3.6) of sqlite in RHEL_5 does not appear to include those functions
(RHEL_6 has sqlite version 3.6.20 which does contain those functions).
You *may* be able to build gdal without sqlite but I have never tried.
Andrew C Aitchison
