[gdal-dev] Next maintenance releases
Even Rouault even.rouault at spatialys.com
Fri Jun 24 13:03:03 PDT 2016
Stefan,
> Unfortunately, I did not see earlier that you fixed
> https://trac.osgeo.org/gdal/ticket/6503 in trunk. (Seems I have to add
> myself to cc also for tickets reported by me, if I want to follow them?)
Check that your email address is still defined in
https://trac.osgeo.org/gdal/prefs (applies to everyone that hasn't checked
recently). It has been reset a few weeks ago due to a Trac upgrade apparently.
> Not sure if I manage to recover my old Windows build environment, in order
> to test the changes on Windows. In case I should work: I would be very
> happy if the geometry-type-bug-fix could be included in the next 2.1
> release...
I'd prefer that someone confirms that Windows build still work before
backporting.
Actually looking at https://trac.osgeo.org/gdal/changeset/34200, I can see
that fyba_melding.cpp is compiled on Windows, but not on Unix (but that was
already the case before). A bit strange...
> Cheers
> Stefan
http://www.spatialys.com
