[gdal-dev] Amplitude virtual bands for complex datasets ?
Antonio Valentino
antonio.valentino at tiscali.it
Thu Jun 30 10:34:52 PDT 2016
Hi Bugbuster,
Il 30/06/2016 17:16, Bugbuster ha scritto:
> Dear Antonio, dear Even
> I have used the PIXFUN plugin a while ago under Linux, and as far as I
> remember, it *worked pretty well* .
> I have downloaded the last version a few days ago because I need to run some
> tests under *Windows*. I had to add the export instruction for the DLL
> compilation (CPL_DLL macro defined in gdal_port.h). The plugin compiles
> correctly, it is registered at startup.
> However, it seems not to work correctly. I tested the real(), imag() and
> mod() functions. Each time, the number of source rasters (/nSources/) is
> zero (I added a few log to find this out)
> Do you have any idea what could cause this weird behavior ?
the package on githib also contains a test suite
Can you please add a test that triggers the issue on windows?
I will try to look into it.
Also the patch with the CPL_DLL would be appreciated
cheers
Antonio Valentino
