[gdal-dev] Google Summer of Code
Tanuj Kumar
kmrtnjscnc at gmail.com
Mon Mar 14 09:11:43 PDT 2016
Hello Dmitry,
I was reading up on the gdalautotest wiki(
http://trac.osgeo.org/gdal/wiki/TestingNotes), and it says, "After building
with either the old or new generation python bindings, and installing them
(or adding them to your path from the build tree)..."
I could not understand what that means. I guess this is important because
when I tried the commands given on that page, I got the following error :
File "./run_all.py", line 37, in <module>
import gdaltest
File"pymod/gdaltest.py", line 37, in <module>
from osgeo import gdal
ImportError: No module named osgeo
Now, as far as I could understand, it is importing a file called "gdal.py"
from a folder called osgeo. I searched for it, and got its path as
"gdal/swig/python/osgeo, whereas the autotest folder is separate.
So my guess is I have to somehow specify the path of "gdal.py"
Could you or anyone please guide me on how to proceed with this?
Thanks
Tanuj
On Sat, Mar 12, 2016 at 11:00 PM, Tanuj Kumar <kmrtnjscnc at gmail.com> wrote:
> Alright, thank you very much, I'll get to work on it!
> On Sat, Mar 12, 2016 at 10:47 PM, Dmitry Baryshnikov <bishop.dev at gmail.com
> > wrote:
>> Hi Tanuj,
>> I wrote a big letter to the list. There is some answers there. Also I add
>> comments below.
>> Best regards,
>> Dmitry
>> 12.03.2016 10:36, Tanuj Kumar пишет:
>> Sorry for replying so late, got caught up in an exam :)
>> I replaced libpng folder of gdal (frmts/png/libpng) with libpng 1.6.21.
>> And then used ./configure and make install on this test version of gdal,
>> which installed successfully. I used gdalinfo on a png file provided with
>> the libpng 1.6.21 source, to check if it was OK, and it successfully gave
>> the png file details.
>> Is that enough to check the build on the computer?
>> No, the autotests must be passed.
>> I have also tested the gdal library with libpng 1.6.21 on Travis, and the
>> build succeeded.
>> https://travis-ci.org/Raeburn1687/gdal/builds/115487530
>> Would all that be enough to check whether the update was succesful?
>> I expected that travis from main gdal repo checked your PR.
>> PS - Although I have copied the files from libpng 1.6.21 source to the
>> gdal libpng folder, how would I know if any of those files are not required
>> for gdal?
>> You need to see the previous version. Some files not needed (i.e.
>> configures and so on, which already comes from gdal, but legal notice must
>> be present (license, autors, etc.) ). Don't hesitate to ask in list.
>> Thank you
>> Tanuj
>> On Thu, Mar 10, 2016 at 2:07 PM, Dmitry Baryshnikov <bishop.dev at gmail.com
>> > wrote:
>>> Hi Tanuj,
>>> 09.03.2016 13:17, Tanuj Kumar пишет:
>>> Yes, I have looked at the ideas list, and I am currently reading up on
>>> idea no. 16, which is, implementing support for the proposed standard for
>>> incrementally parseable GeoJSON data.
>>> Also, I was thinking that maybe I could work on ticket no 6294,
>>> <https://trac.osgeo.org/gdal/ticket/6294>
>>> after I've studied about the GSoC idea, which is not really a bug, but
>>> an enhancement. But if there are any other tickets that you or anyone else
>>> would like to recommend me to work on, I'd love to see them too!
>>> I think this rather arguing ticket as the bool is not exist in plain C,
>>> and duplication functions seems to me not good idea.
>>> I think this ticket https://trac.osgeo.org/gdal/ticket/6185 is good
>>> for: 1. building GDAL, 2. Testing via TraviC on GitHub. By the way the
>>> libpng version is 1.6.21 or maybe higher.
>>> Anyhow, you have to try to build gdal and test it with autotests from
>>> appropriate folder.
>>> Now, about the GSoC idea, do I need to know JSON( or GeoJSON, for that
>>> matter) to work on it? I only ask because the idea lists C/C++ as the
>>> required skills, but I feel that maybe this work would involve knowing JSON
>>> too...
>>> Yes, certainly. But JSON are very simple. Also GeoJSON spec. can be
>>> found here http://geojson.org/Thanks and regards,
>>> Tanuj
>>> On Wed, Mar 9, 2016 at 2:58 PM, Dmitry Baryshnikov <
>>> <bishop.dev at gmail.com>bishop.dev at gmail.com> wrote:
>>>> Hi, Tanuj
>>>> I'll look for opened tickets for you, or maybe others can recommend
>>>> some for you.
>>>> By the way, do you see the idea list (
>>>> <https://trac.osgeo.org/gdal/wiki/SummerOfCode#a2016IdeasList>
>>>> https://trac.osgeo.org/gdal/wiki/SummerOfCode#a2016IdeasList)?
>>>> The ideas are not ranked yet - the numbers in the list - are only in
>>>> order.
>>>> This is a task for us to rank the ideas.
>>>> But, have you some preferable idea (or ideas) for GSoC from this list
>>>> or maybe you have got own?
>>>> Best regards,
>>>> Dmitry
>>>> 04.03.2016 16:11, Tanuj Kumar пишет:
>>>> Hello,
>>>> I am interested in applying for GSoC this year. Currently, I am reading
>>>> up on the GDAL Summer of Code ideas list. I know C++ and C, and I have some
>>>> experience on working on linux.
>>>> Could the mentors please recommend a bug for me to work on, I'd really
>>>> love to start off as soon as possible!
>>>> Thank you,
>>>> Tanuj Kumar
>>>> Birla institute of Technology and Science
>>>> Pilani, Rajasthan,
>>>> India
>>>> _______________________________________________
>>>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> Best regards,
>>> Dmitry
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160314/b54356d2/attachment.html>
