[gdal-dev] Google Summer of Code
Dmitry Baryshnikov bishop.dev at gmail.com
Mon Mar 14 12:54:16 PDT 2016
Hi Tanuj,
The error: ImportError: No module named osgeo
is because you build gdal without python support (you need python with
developers headers).
On Linux Linux this is done via such command:
./configure --with-python ... <other config options>
On Windows it depends how you build. On Windows I launch separate tests
successfully but never try the whole tests (run_all.py).
Best regards,
     Dmitry
14.03.2016 19:11, Tanuj Kumar пишет:
> Hello Dmitry,
> I was reading up on the gdalautotest
> wiki(http://trac.osgeo.org/gdal/wiki/TestingNotes), and it says,
> "After building with either the old or new generation python bindings,
> and installing them (or adding them to your path from the build tree)..."
> I could not understand what that means. I guess this is important
> because when I tried the commands given on that page, I got the
> following error :
> File "./run_all.py", line 37, in <module>
> import gdaltest
> File"pymod/gdaltest.py", line 37, in <module>
> from osgeo import gdal
> Now, as far as I could understand, it is importing a file called
> "gdal.py" from a folder called osgeo. I searched for it, and got its
> path as "gdal/swig/python/osgeo, whereas the autotest folder is separate.
> So my guess is I have to somehow specify the path of "gdal.py"
> Could you or anyone please guide me on how to proceed with this?
> Thanks
> Tanuj
> On Sat, Mar 12, 2016 at 11:00 PM, Tanuj Kumar <kmrtnjscnc at gmail.com
> <mailto:kmrtnjscnc at gmail.com>> wrote:
>     Alright, thank you very much, I'll get to work on it!
>     On Sat, Mar 12, 2016 at 10:47 PM, Dmitry Baryshnikov
>     <bishop.dev at gmail.com <mailto:bishop.dev at gmail.com>> wrote:
>         Hi Tanuj,
>         I wrote a big letter to the list. There is some answers there.
>         Also I add comments below.
>         Best regards,
>              Dmitry
>         12.03.2016 10:36, Tanuj Kumar пишет:
>>         Sorry for replying so late, got caught up in an exam :)
>>         I replaced libpng folder of gdal (frmts/png/libpng) with
>>         libpng 1.6.21. And then used ./configure and make install on
>>         this test version of gdal, which installed successfully. I
>>         used gdalinfo on a png file provided with the libpng 1.6.21
>>         source, to check if it was OK, and it successfully gave the
>>         png file details.
>>         Is that enough to check the build on the computer?
>         No, the autotests must be passed.
>>         I have also tested the gdal library with libpng 1.6.21 on
>>         Travis, and the build succeeded.
>>         https://travis-ci.org/Raeburn1687/gdal/builds/115487530
>>         Would all that be enough to check whether the update was
>>         succesful?
>         I expected that travis from main gdal repo checked your PR.
>>         PS - Although I have copied the files from libpng 1.6.21
>>         source to the gdal libpng folder, how would I know if any of
>>         those files are not required for gdal?
>         You need to see the previous version. Some files not needed
>         (i.e. configures and so on, which already comes from gdal, but
>         legal notice must be present (license, autors, etc.) ). Don't
>         hesitate to ask in list.
>>         Thank you
>>         Tanuj
>>         On Thu, Mar 10, 2016 at 2:07 PM, Dmitry Baryshnikov
>>             Hi Tanuj,
>>             09.03.2016 13:17, Tanuj Kumar пишет:
>>>             Yes, I have looked at the ideas list, and I am currently
>>>             reading up on idea no. 16, which is, implementing
>>>             support for the proposed standard for incrementally
>>>             parseable GeoJSON data.
>>>             Also, I was thinking that maybe I could work on ticket
>>>             no 6294, https://trac.osgeo.org/gdal/ticket/6294
>>>             after I've studied about the GSoC idea, which is not
>>>             really a bug, but an enhancement. But if there are any
>>>             other tickets that you or anyone else would like to
>>>             recommend me to work on, I'd love to see them too!
>>             I think this rather arguing ticket as the bool is not
>>             exist in plain C, and duplication functions seems to me
>>             not good idea.
>>             I think this ticket
>>             https://trac.osgeo.org/gdal/ticket/6185 is good for: 1.
>>             building GDAL, 2. Testing via TraviC on GitHub. By the
>>             way the libpng version is 1.6.21 or maybe higher.
>>             Anyhow, you have to try to build gdal and test it with
>>             autotests from appropriate folder.
>>>             Now, about the GSoC idea, do I need to know JSON( or
>>>             GeoJSON, for that matter) to work on it? I only ask
>>>             because the idea lists C/C++ as the required skills, but
>>>             I feel that maybe this work would involve knowing JSON
>>>             too...
>>             Yes, certainly. But JSON are very simple. Also GeoJSON
>>             spec. can be found here http://geojson.org/Thanks and
>>             regards,
>>>             Tanuj
>>>             On Wed, Mar 9, 2016 at 2:58 PM, Dmitry Baryshnikov
>>>                 Hi, Tanuj
>>>                 I'll look for opened tickets for you, or maybe
>>>                 others can recommend some for you.
>>>                 By the way, do you see the idea list
>>>                 (https://trac.osgeo.org/gdal/wiki/SummerOfCode#a2016IdeasList)?
>>>                 The ideas are not ranked yet - the numbers in the
>>>                 list - are only in order.
>>>                 This is a task for us to rank the ideas.
>>>                 But, have you some preferable idea (or ideas) for
>>>                 GSoC from this list or maybe you have got own?
>>>                 Best regards,
>>>                      Dmitry
>>>                 04.03.2016 16:11, Tanuj Kumar пишет:
>>>>                 Hello,
>>>>                 I am interested in applying for GSoC this year.
>>>>                 Currently, I am reading up on the GDAL Summer of
>>>>                 Code ideas list. I know C++ and C, and I have some
>>>>                 experience on working on linux.
>>>>                 Could the mentors please recommend a bug for me to
>>>>                 work on, I'd really love to start off as soon as
>>>>                 possible!
>>>>                 Thank you,
>>>>                 Tanuj Kumar
>>>>                 Birla institute of Technology and Science
>>>>                 Pilani, Rajasthan,
>>>>                 India
>>>>                 _______________________________________________
>>>>                 gdal-dev mailing list
>>>>                 gdal-dev at lists.osgeo.org
>>>>                 <mailto:gdal-dev at lists.osgeo.org>
>>>>                 http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>             Best regards,
>>                  Dmitry
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160314/63840dfa/attachment-0001.html>
