[gdal-dev] New config option for date/time output
Ari Jolma ari.jolma at gmail.com
Tue Mar 15 06:01:29 PDT 2016
15.03.2016, 14:08, Joaquim Luis kirjoitti:
> GMT uses "yyy-mm-ddT[hh:mm:ss] (Gregorian) or yyyy-Www-ddT[hh:mm:ss]
> (ISO)"
> http://gmt.soest.hawaii.edu/doc/latest/gmt.conf.html#calendar-time-parameters
> It would be nice to use the same.
I'm not sure I understand you correctly but strftime can do this:
OGR_DATETIME_FORMAT = "%Y-%m-%dT%H:%M:%S"
gives for example 2016-01-10T08:25:12 and
OGR_DATETIME_FORMAT = "%Y-%W-%dT%H:%M:%S"
gives 2016-01-10T08:25:12 for the same time - 10.1.2016 is on week two
(strftime: %W = Week number with the first Monday as the first day of
week one (00-53))
I think that there needs to be separate options for date and datetime,
i.e., OGR_DATE_FORMAT and OGR_DATETIME_FORMAT.
Ari
> Joaquim
>> Folks,
>> The OGRFeature::GetFieldAsString returns date/time fields formatted
>> in non-standard way. For example date is output as "year/month/day"
>> as more usual "year-month-day". This causes problems in many programs.
>> I suggest adding a new config option OGR_DATE_FORMAT, which, if set,
>> would make the method return date/time formatted according to it. I
>> suggest that we use the strftime and its format argument as the
>> target for the new option.
>> The implementation is complicated a bit when milliseconds and
>> timezones are involved since they are not included in the struct tm
>> used by strftime. I suggest that we assume seconds are formatted as
>> :\d\d in the format and simply add milliseconds (as .\d\d\d) and
>> timezone (as [+-]\d\d(:\d\d)), if they exists, after the second.
>> Do you think this needs a RFC?
>> I'm willing to implement the changes.
>> Ari
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
