[gdal-dev] New config option for date/time output
Joaquim Luis
jluis at ualg.pt
Tue Mar 15 06:59:53 PDT 2016
On Tue, 15 Mar 2016 13:01:29 -0000, Ari Jolma <ari.jolma at gmail.com> wrote:
> 15.03.2016, 14:08, Joaquim Luis kirjoitti:
>> GMT uses "yyy-mm-ddT[hh:mm:ss] (Gregorian) or yyyy-Www-ddT[hh:mm:ss]
>> (ISO)"
>> http://gmt.soest.hawaii.edu/doc/latest/gmt.conf.html#calendar-time-parameters
>> It would be nice to use the same.
> I'm not sure I understand you correctly but strftime can do this:
> OGR_DATETIME_FORMAT = "%Y-%m-%dT%H:%M:%S"
> gives for example 2016-01-10T08:25:12 and
> OGR_DATETIME_FORMAT = "%Y-%W-%dT%H:%M:%S"
> gives 2016-01-10T08:25:12 for the same time - 10.1.2016 is on week two
> (strftime: %W = Week number with the first Monday as the first day of
> week one (00-53))
Sorry, it was me who misunderstood your question/suggestion. I thought
that printing with the above format was not possible yet and that's why I
pointed to what GMT does. But if GDAL can do it already, than sorry for
the noise.
Joaquim
> I think that there needs to be separate options for date and datetime,
> i.e., OGR_DATE_FORMAT and OGR_DATETIME_FORMAT.
> Ari
>> Joaquim
>>> Folks,
>>> The OGRFeature::GetFieldAsString returns date/time fields formatted in
>>> non-standard way. For example date is output as "year/month/day" as
>>> more usual "year-month-day". This causes problems in many programs.
>>> I suggest adding a new config option OGR_DATE_FORMAT, which, if set,
>>> would make the method return date/time formatted according to it. I
>>> suggest that we use the strftime and its format argument as the target
>>> for the new option.
>>> The implementation is complicated a bit when milliseconds and
>>> timezones are involved since they are not included in the struct tm
>>> used by strftime. I suggest that we assume seconds are formatted as
>>> :\d\d in the format and simply add milliseconds (as .\d\d\d) and
>>> timezone (as [+-]\d\d(:\d\d)), if they exists, after the second.
>>> Do you think this needs a RFC?
>>> I'm willing to implement the changes.
>>> Ari
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
