[gdal-dev] Transformation methods & parameters (OGRCoordinateTransformation)
Andre Joost
andre+joost at nurfuerspam.de
Fri Mar 18 11:14:31 PDT 2016
Am 18.03.2016 um 18:57 schrieb César Martínez:
> Thanks André, datum_shift.csv is (partially) what I was looking for.
> I see however that EPSG:15933 transformation operation is missing on
> that list (which in this Spanish example is usually the most accurate
> one), maybe because it uses the NTv2 method.
> In any case, how can I use the datum_shift.csv parameters to construct
> a OGRCoordinateTransformation instance?
The parameters go into the +towgs84 parameter string of GDAL/Proj.4.
NTv2 grids are treated differently, you have to apply +nadgrids and the
path to the file.
HTH,
André Joost
