[gdal-dev] GDAL 2.1 and Norwegian SOSI
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Wed May 4 00:32:13 PDT 2016
Hei again,
First of all, now the SOSI file opens fine again. So, many thanks for that!
Unfortunately, I now get a new error on ogrinfo ./ADM_kommune_0620_Hol.sos lines
Layer name: lines
Geometry: Line String
ERROR 4: Unrecognized geometry of type 5.
ERROR 1: Feature 82 referenced by 2204, but it was not initialized.
Aborted (core dumped)
I get it for polygons too. Geometries of type 5 are curved geometries which got introduced in SOSI version 4.5 - if I am not mistaken...
Geometry type 5 (BUEP) is defined in https://github.com/kartverket/fyba/blob/master/src/FYBA/fyba.h (Line 408)... Would it be sufficient to add something like:
case wkbCompoundCurve: {
pszSosi = ".BUEP";
break;
to: ogr/ogrsf_frmts/sosi/ogrsosilayer.cpp (not sure if the translation is 100% correct)
But maybe also trunk/gdal/ogr/ogrsf_frmts/sosi/ogrsosidatasource.cpp needs modification...?
(I am no programmer).
Seems to be an older issue and other GeometryTypes seem to cause trouble too:
http://gis.stackexchange.com/questions/132888/ogr2ogr-problem-converting-sosi-fil-to-kml-or-anything-else
Cheers,
Stefan
-----Original Message-----
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: 3. mai 2016 21:33
To: gdal-dev at lists.osgeo.org
Cc: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>
Subject: Re: [gdal-dev] GDAL 2.1 and Norwegian SOSI
Le mardi 03 mai 2016 21:06:14, Blumentrath, Stefan a écrit :
> Dear GDAL-devs,
> I just tried to open a Norwegian SOSI file with ogrinfo from GDAL
> 2.1dev but get: FAILURE:
> Unable to open datasource `./ADM_kommune_2018_Masoy.sos' with the
> following drivers.
> 'ogrinfo --formats' does not list the SOSI driver either. But I am
> sure I did compile with '--with-sosi' and gdal-config --dep-libs lists
> the openfyba libs used for the driver.
Hum, I see this is actually a 2.1.0 regression.
Fix available in https://trac.osgeo.org/gdal/ticket/6500
> So my question is,: were there any changes from 1.11 to 2.x which may
> affect the driver? Any chance someone will make that working again?
> Unfortunately our mapping authority does not seem to be maintaining
> the OpenFYBA lib any more (SOSI version 4.5 not yet supported), so I
> can understand if you are not too keen on fixing the issue (if it is
> not local).
> Thanks for any help.
> Kind regards,
> Stefan
Spatialys - Geospatial professional services http://www.spatialys.com
