[gdal-dev] GDAL 2.1 and Norwegian SOSI
Even Rouault
even.rouault at spatialys.com
Wed May 4 00:48:35 PDT 2016
Le mercredi 04 mai 2016 09:32:13, Blumentrath, Stefan a écrit :
> Hei again,
> First of all, now the SOSI file opens fine again. So, many thanks for that!
> Unfortunately, I now get a new error on ogrinfo ./ADM_kommune_0620_Hol.sos
> lines
> Layer name: lines
> Geometry: Line String
> ERROR 4: Unrecognized geometry of type 5.
> ERROR 1: Feature 82 referenced by 2204, but it was not initialized.
> Aborted (core dumped)
> I get it for polygons too. Geometries of type 5 are curved geometries which
> got introduced in SOSI version 4.5 - if I am not mistaken...
> Geometry type 5 (BUEP) is defined in
> https://github.com/kartverket/fyba/blob/master/src/FYBA/fyba.h (Line
> 408)... Would it be sufficient to add something like: case
> wkbCompoundCurve: {
> pszSosi = ".BUEP";
> break;
> to: ogr/ogrsf_frmts/sosi/ogrsosilayer.cpp (not sure if the translation is
> 100% correct)
That would be for the write side of the driver. GetNextFeature() should likely
be modified
> But maybe also trunk/gdal/ogr/ogrsf_frmts/sosi/ogrsosidatasource.cpp needs
> modification...? (I am no programmer).
Yes, the Open() method seems to be where OGR geometries are built from SOSI
ones. Would need to be extended for curves.
> Seems to be an older issue and other GeometryTypes seem to cause trouble
> too:
> http://gis.stackexchange.com/questions/132888/ogr2ogr-problem-converting-s
> osi-fil-to-kml-or-anything-else
> Cheers,
> Stefan
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at spatialys.com]
> Sent: 3. mai 2016 21:33
> To: gdal-dev at lists.osgeo.org
> Cc: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>
> Subject: Re: [gdal-dev] GDAL 2.1 and Norwegian SOSI
> Le mardi 03 mai 2016 21:06:14, Blumentrath, Stefan a écrit :
> > Dear GDAL-devs,
> > I just tried to open a Norwegian SOSI file with ogrinfo from GDAL
> > 2.1dev but get: FAILURE:
> > Unable to open datasource `./ADM_kommune_2018_Masoy.sos' with the
> > following drivers.
> > 'ogrinfo --formats' does not list the SOSI driver either. But I am
> > sure I did compile with '--with-sosi' and gdal-config --dep-libs lists
> > the openfyba libs used for the driver.
> Hum, I see this is actually a 2.1.0 regression.
> Fix available in https://trac.osgeo.org/gdal/ticket/6500
> > So my question is,: were there any changes from 1.11 to 2.x which may
> > affect the driver? Any chance someone will make that working again?
> > Unfortunately our mapping authority does not seem to be maintaining
> > the OpenFYBA lib any more (SOSI version 4.5 not yet supported), so I
> > can understand if you are not too keen on fixing the issue (if it is
> > not local).
> > Thanks for any help.
> > Kind regards,
> > Stefan
> Spatialys - Geospatial professional services http://www.spatialys.com
