[gdal-dev] Creation of pages on Trac wiki disabled
Even Rouault
even.rouault at spatialys.com
Wed May 4 14:24:59 PDT 2016
Le mercredi 04 mai 2016 18:49:28, Even Rouault a écrit :
> Le mercredi 04 mai 2016 10:16:32, Even Rouault a écrit :
> > Le lundi 02 mai 2016 11:35:17, Even Rouault a écrit :
> > > Le mercredi 27 avril 2016 21:59:01, Even Rouault a écrit :
> > > > Folks,
> > > > I've removed the right to create new pages on the wiki for the
> > > > 'authenticated' group due to spammers abusting it recently (as well
> > > > as other projects wiki). OSGeo System Administration Committee is
> > > > looking at that, so we might re- enable that if we understand what
> > > > happens. If you need to create pages, ping me and I can give you the
> > > > permission.
> > > OSGeo id creation has been hardened, so I've re-enabled wiki page
> > > creation for authenticated users. Please keep an eye if spammers start
> > > abusing it again.
> > Sigh, I had to disable wiki page creation again as spammers start again.
> > It seems they create manually their OSGeo id, so anti-bot measures at
> > that level don't help.
> We just got spam in a ticket. I've enabled the right to delete (not close,
> real delete) tickets to foks with TRAC_ADMIN priviledges (ie PSC members.
> Just added you Jukka). This should only be used to delete spam.
> I hope we won't have to use it a lot... Not sure about what we could do if
> tickets got massively spammed.
Wiki page re-enabled for authenticated users.
Strk has installed the https://trac.edgewall.org/wiki/SpamFilter plugin so we
have now a number of settings to play with to limit the spam. PSC members
should see the different "spam filtering" settings in the Administration pannel
https://trac.osgeo.org/gdal/admin . According to the advices of
https://trac.edgewall.org/wiki/SpamFilter, we'll have to play in priority with
the Bayes filter in priority to sort good vs spam content. If someone gets
legit content rejected, let us know.
> > > > Even
http://www.spatialys.com
