[gdal-dev] Starting a discussion on style and coding guidelines
Joaquim Luis
jluis at ualg.pt
Mon May 9 08:14:39 PDT 2016
There is one aspect of the coding style that I honestly do not understand.
Why continuing to recommend the 80 chars line width? I don't by the
readability argument, well on the contrary, if because of it the result is
an excess 'verticalization' of the code it becomes much harder to read.
I don't know for you guys but when I'm forced to permanently scroll up and
down it becomes really much harder to study a code. For me the ideal is
that a function holds in a single screen size, but ofc without piling up
everything to reach that goal.
A little example from gdaldem_lib.cpp (line 240)
****************** Current code *********************************
for ( i = 0; i < 2 && i < nYSize; i++)
if( GDALRasterIO( hSrcBand,
GF_Read,
0, i,
nXSize, 1,
pafThreeLineWin + i * nXSize,
nXSize, 1,
GDT_Float32,
0, 0) != CE_None )
eErr = CE_Failure;
goto end;
************ What I think would be reasonable
for (i = 0; i < 2 && i < nYSize; i++) {
if (GDALRasterIO(hSrcBand, GF_Read, 0, i, nXSize, 1,
pafThreeLineWin + i * nXSize, nXSize, 1,
GDT_Float32, 0, 0) != CE_None ) {
eErr = CE_Failure;
goto end;
7 lines instead of 15, and is it less readable (in a text editor, not in a
mail client)?
Joaquim
> On 9 May 2016 at 09:15, Ari Jolma <ari.jolma at gmail.com> wrote:
>> 05.05.2016, 01:30, Kurt Schwehr kirjoitti:
>> Hi all,
>> If you've been watching the timeline on trac, you have probably seen a
>> large
>> number of cleanup CLs from me. It's definitely past time to get some
>> discussion going on these changes. If the community likes these, we
>> can add
>> them to rfc8_devguide.
>> It is very minimal right now. Good style guides tend to be quite large,
>> e.g., https://google.github.io/styleguide/cppguide.html or
>> http://geosoft.no/development/cppstyle.html
> Good C++ guidelines that fit on a single page is all you need
> these days, after Bjarne Stroustrup
> https://parasol.tamu.edu/people/bs/622-GP/C++11-style.pdf
> Best regards,
