[gdal-dev] Starting a discussion on style and coding guidelines
Ari Jolma
ari.jolma at gmail.com
Mon May 9 08:44:48 PDT 2016
I like one statement per line because it helps walking through the code
with gdb; you can see the whole statement that is going to be executed.
I also share the idea that seeing a whole subroutine or a logical part
at once helps understanding the code.
Ari
09.05.2016, 18:14, Joaquim Luis kirjoitti:
> Hi,
> There is one aspect of the coding style that I honestly do not
> understand. Why continuing to recommend the 80 chars line width? I
> don't by the readability argument, well on the contrary, if because of
> it the result is an excess 'verticalization' of the code it becomes
> much harder to read.
> I don't know for you guys but when I'm forced to permanently scroll up
> and down it becomes really much harder to study a code. For me the
> ideal is that a function holds in a single screen size, but ofc
> without piling up everything to reach that goal.
> A little example from gdaldem_lib.cpp (line 240)
> ****************** Current code *********************************
> for ( i = 0; i < 2 && i < nYSize; i++)
> if( GDALRasterIO( hSrcBand,
> GF_Read,
> 0, i,
> nXSize, 1,
> pafThreeLineWin + i * nXSize,
> nXSize, 1,
> GDT_Float32,
> 0, 0) != CE_None )
> eErr = CE_Failure;
> goto end;
> ************ What I think would be reasonable
> for (i = 0; i < 2 && i < nYSize; i++) {
> if (GDALRasterIO(hSrcBand, GF_Read, 0, i, nXSize, 1,
> pafThreeLineWin + i * nXSize, nXSize, 1,
> GDT_Float32, 0, 0) != CE_None ) {
> eErr = CE_Failure;
> goto end;
> 7 lines instead of 15, and is it less readable (in a text editor, not
> in a mail client)?
> Joaquim
>> On 9 May 2016 at 09:15, Ari Jolma <ari.jolma at gmail.com> wrote:
>>> 05.05.2016, 01:30, Kurt Schwehr kirjoitti:
>>> Hi all,
>>> If you've been watching the timeline on trac, you have probably seen
>>> a large
>>> number of cleanup CLs from me. It's definitely past time to get some
>>> discussion going on these changes. If the community likes these, we
>>> can add
>>> them to rfc8_devguide.
>>> It is very minimal right now. Good style guides tend to be quite large,
>>> e.g., https://google.github.io/styleguide/cppguide.html or
>>> http://geosoft.no/development/cppstyle.html
>> Good C++ guidelines that fit on a single page is all you need
>> these days, after Bjarne Stroustrup
>> https://parasol.tamu.edu/people/bs/622-GP/C++11-style.pdf
>> Best regards,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
