[gdal-dev] VRT and M-dimension - any example?
Even Rouault
even.rouault at spatialys.com
Tue May 10 05:43:16 PDT 2016
Le mardi 10 mai 2016 14:38:01, Jukka Rahkonen a écrit :
> Hi,
> Release notes https://trac.osgeo.org/gdal/wiki/Release/2.1.0-News announce
> that RFC 61: Support for measured geometries is implemented in VRT.
> However, this is not mentioned in http://www.gdal.org/drv_vrt.html. I
> would like to improve the documentation but before I can do that I need to
> understand how it works. Could somebody help a bit with making a valid VRT
> for
> - CSV source
> - GeometryType>wkbPointZM</GeometryType>
> - GeometryField encoding="PointFromColumns"
> Or are the PointFromColumn attributes simply x="x" y="y" z="z" m="m" ?
Ah good point, PointFromColumn has not been extended to support the m
attribute. The support for M / ZM is just in passthrough mode :
pointzm.csv:
id,WKT
1,"POINT ZM (1 2 3 4)"
pointzm.vrt:
<OGRVRTDataSource>
<OGRVRTLayer name="pointzm">
<SrcDataSource relativeToVRT="1">pointzm.csv</SrcDataSource>
<SrcLayer>pointzm</SrcLayer>
<GeometryType>wkbPointZM</GeometryType>
</OGRVRTLayer>
</OGRVRTDataSource>
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
