[gdal-dev] Importing KML to Mysql with extended data fields
Even Rouault
even.rouault at spatialys.com
Thu May 26 08:27:29 PDT 2016
Shawn
I suppose that your GDAL build has only the KML driver built in. It doesn't
support reading SimpleData. For that, you need to build GDAL against libkml to
have the LIBKML driver : http://gdal.org/drv_libkml.html
Even
> I'm trying to import a KML file that has a bunch of SimpleData fields
> inside of ExtendedData into mysql.
> I've gotten the basic syntax down for importing the file, but I can't seem
> to get the simpledata fileds to transfer over.
> Here's an example. I don't really need all the fields -- I'm only really
> interested in storing the polygon and the GEOID10 field, but I can
> manipulate the database to remove them later easily enough.
> <Placemark>
> <styleUrl>#falseColor0</styleUrl>
> <ExtendedData>
> <SchemaData schemaUrl="#S_tl_2015_26_tabblock10_SSSSSSSS
> SSSDDSS">
> <SimpleData name="STATEFP10">13</SimpleData>
> <SimpleData name="COUNTYFP10">131</SimpleData>
> <SimpleData name="TRACTCE10">970100</SimpleData>
> <SimpleData name="BLOCKCE10">1125</SimpleData>
> <SimpleData name="GEOID10">131319701001125</Simp
> leData>
> <SimpleData name="NAME10">Block 1125</SimpleData
> <SimpleData name="MTFCC10">G5040</SimpleData>
> <SimpleData name="UR10">R</SimpleData>
> <SimpleData name="UACE10"></SimpleData>
> <SimpleData name="UATYPE"></SimpleData>
> <SimpleData name="FUNCSTAT10">S</SimpleData>
> <SimpleData name="ALAND10">9.67522e+06</SimpleDa
> ta>
> <SimpleData name="AWATER10">4866</SimpleData>
> <SimpleData name="INTPTLAT10">+46.7776681</Simpl
> eData>
> <SimpleData name="INTPTLON10">-088.9520440</Simp
> leData>
> </SchemaData>
> </ExtendedData>
> <Polygon>
> <outerBoundaryIs>
> <LinearRing>
> <coordinates>
http://www.spatialys.com
