[gdal-dev] EPSG code not recognized from GeoTiff written by GDAL
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Fri May 27 15:20:29 PDT 2016
And thanks Even and Jukka for your answers!
Based on the info you provided I investigated a bit more and it seems to be an issue "downstreams" indeed.
gdalsrsinfo epsg:25832 gave the same result for me than for Jukka (the result from listgeo further down, just for the record).
In GRASS GIS 7.0.4 and 7.1.svn, g.proj -w gave me the projection information as in the GeoTIFF, though without any AUTHORITY parameters (as it is supposed to according to the manual). The AUTHORITY tags seem to be added by r.out.gdal, except for the authority parameter for the entire projection... Even if g.proj -g returns epsg=25832...
gdal_translate -a_srs EPSG:25832 in.tif out.tif adds the AUTHORITY parameter to the GeoTIFF, while gdal_edit -a_srs EPSG:25832 does not.
Kind regards,
Stefan
P.S.: This is the output from listgeo LC81980182015183LGN00_LST_const_LC.tif
TIFFReadDirectory: Warning, Unknown field with tag 42112 (0xa480) encountered.
TIFFReadDirectory: Warning, Unknown field with tag 42113 (0xa481) encountered.
Geotiff_Information:
Version: 1
Key_Revision: 1.0
Tagged_Information:
ModelTiepointTag (2,3):
0 0 0
417585 6784515 0
ModelPixelScaleTag (1,3):
30 30 0
End_Of_Tags.
Keyed_Information:
GTModelTypeGeoKey (Short,1): ModelTypeProjected
GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
GTCitationGeoKey (Ascii,30): "Universal Transverse Mercator"
GeographicTypeGeoKey (Short,1): User-Defined
GeogCitationGeoKey (Ascii,80): "GCS Name = grs80|Ellipsoid = Geodetic_Refe
rence_System_1980|Primem = Greenwich|"
GeogGeodeticDatumGeoKey (Short,1): Datum_European_Reference_System_1989
GeogAngularUnitsGeoKey (Short,1): Angular_Degree
GeogSemiMajorAxisGeoKey (Double,1): 6378137
GeogInvFlatteningGeoKey (Double,1): 298.257222101
GeogPrimeMeridianLongGeoKey (Double,1): 0
ProjectedCSTypeGeoKey (Short,1): User-Defined
ProjectionGeoKey (Short,1): Proj_UTM_zone_32N
ProjLinearUnitsGeoKey (Short,1): Linear_Meter
End_Of_Keys.
End_Of_Geotiff.
Projection = 16032 (UTM zone 32N)
Projection Method: CT_TransverseMercator
ProjNatOriginLatGeoKey: 0.000000 ( 0d 0' 0.00"N)
ProjNatOriginLongGeoKey: 9.000000 ( 9d 0' 0.00"E)
ProjScaleAtNatOriginGeoKey: 0.999600
ProjFalseEastingGeoKey: 500000.000000 m
ProjFalseNorthingGeoKey: 0.000000 m
Datum: 6258/European Terrestrial Reference System 1989
Ellipsoid: 7019/GRS 1980 (6378137.00,6356752.31)
Projection Linear Units: 9001/metre (1.000000m)
Corner Coordinates:
Upper Left ( 417585.000, 6784515.000) ( 7d28' 1.67"E, 61d11'11.02"N)
Lower Left ( 417585.000, 6538485.000) ( 7d33'58.86"E, 58d58'40.77"N)
Upper Right ( 660915.000, 6784515.000) ( 11d59'28.13"E, 61d 9'43.28"N)
Lower Right ( 660915.000, 6538485.000) ( 11d47'51.98"E, 58d57'20.48"N)
Center ( 539250.000, 6661500.000) ( 9d42'20.11"E, 60d 5'19.35"N)
-----Original Message-----
From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Even Rouault
Sent: 27. mai 2016 14:28
To: gdal-dev at lists.osgeo.org
Cc: Jukka Rahkonen <jukka.rahkonen at maanmittauslaitos.fi>
Subject: Re: [gdal-dev] EPSG code not recognized from GeoTiff written by GDAL
On Friday 27 May 2016 11:46:14 Jukka Rahkonen wrote:
> Blumentrath, Stefan <Stefan.Blumentrath <at> nina.no> writes:
> > Hei,
> > We are facing issues with GeoTiffs that were written by GDAL, after
> importing them to GeoServer or opening in Desktop GIS.
> > On file was produced in GRASS and exported using r.out.gdal (GDAL
> > 2.1dev),
> the other file in R, using rgdal (GDAL2.0.x) with EPSG code 25832.
> > The rasters seem to miss the AUTHORITY parameter...
> > QGIS for example detects EPSG 3044 (which is technically identical),
> > and
> GeoServer considers the CRS as invalid (because of this:
> http://docs.geonode.org/en/master/tutorials/advanced/geonode_productio
> n/adv_
> gsconfig/crs_handling.html).
> > Did anyone else experience the same?
> Hi,
> From my GDAL 2.1-dev
> PROJ.4 : '+proj=utm +zone=32 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0
> +units=m
> +no_de fs '
> OGC WKT :
> PROJCS["ETRS89 / UTM zone 32N",
> GEOGCS["ETRS89",
> DATUM["European_Terrestrial_Reference_System_1989",
> SPHEROID["GRS 1980",6378137,298.257222101,
> AUTHORITY["EPSG","7019"]],
> TOWGS84[0,0,0,0,0,0,0],
> AUTHORITY["EPSG","6258"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4258"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",9],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AXIS["Easting",EAST],
> AXIS["Northing",NORTH],
> AUTHORITY["EPSG","25832"]]
> Do you get the same result? If you do I wonder why AUTHORITY is not
> written into GeoTIFF.
For diagnosing, what is interesting is the output of the listgeo utility that comes with libgeotiff.
Theoretically the EPSG code should be preserved in the geotiff keys if it is available in the source raster (gdal_translate use case), or if set with the
SetProjection() API. I'm not sure about GRASS or R but perhaps they build the GDAL SRS object from a proj.4 string, in which case the EPSG code will be missing.
> -Jukka Rahkonen-
> > Kind regards,
> > Stefan
> gdal-dev mailing list
Spatialys - Geospatial professional services http://www.spatialys.com _______________________________________________
