[gdal-dev] EPSG code not recognized from GeoTiff written by GDAL
Even Rouault
even.rouault at spatialys.com
Fri May 27 15:48:11 PDT 2016
> gdal_translate -a_srs EPSG:25832 in.tif out.tif adds the AUTHORITY parameter
> to the GeoTIFF, while gdal_edit -a_srs EPSG:25832 does not.
That's weird that gdal_edit does'nt set it correctly. I just tested it and it
works for me.
$ cp autotest/gcore/data/byte.tif tmp.tif; python
gdal/swig/python/scripts/gdal_edit.py -a_srs EPSG:25832 tmp.tif
$ gdalinfo tmp.tif
Driver: GTiff/GeoTIFF
Files: tmp.tif
Size is 20, 20
Coordinate System is:
PROJCS["ETRS89 / UTM zone 32N",
GEOGCS["ETRS89",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6258"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4258"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",9],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["Easting",EAST],
AXIS["Northing",NORTH],
AUTHORITY["EPSG","25832"]]
> Kind regards,
> Stefan
> P.S.: This is the output from listgeo
> LC81980182015183LGN00_LST_const_LC.tif
TIFFReadDirectory: Warning, Unknown
> field with tag 42112 (0xa480) encountered. TIFFReadDirectory: Warning,
> Unknown field with tag 42113 (0xa481) encountered. Geotiff_Information:
> Version: 1
> Key_Revision: 1.0
> Tagged_Information:
> ModelTiepointTag (2,3):
> 0 0 0
> 417585 6784515 0
> ModelPixelScaleTag (1,3):
> 30 30 0
> End_Of_Tags.
> Keyed_Information:
> GTModelTypeGeoKey (Short,1): ModelTypeProjected
> GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
> GTCitationGeoKey (Ascii,30): "Universal Transverse Mercator"
> GeographicTypeGeoKey (Short,1): User-Defined
> GeogCitationGeoKey (Ascii,80): "GCS Name = grs80|Ellipsoid =
> Geodetic_Refe
rence_System_1980|Primem = Greenwich|"
> GeogGeodeticDatumGeoKey (Short,1):
> Datum_European_Reference_System_1989
GeogAngularUnitsGeoKey (Short,1):
> Angular_Degree
> GeogSemiMajorAxisGeoKey (Double,1): 6378137
> GeogInvFlatteningGeoKey (Double,1): 298.257222101
> GeogPrimeMeridianLongGeoKey (Double,1): 0
> ProjectedCSTypeGeoKey (Short,1): User-Defined
> ProjectionGeoKey (Short,1): Proj_UTM_zone_32N
> ProjLinearUnitsGeoKey (Short,1): Linear_Meter
> End_Of_Keys.
> End_Of_Geotiff.
> Projection = 16032 (UTM zone 32N)
> Projection Method: CT_TransverseMercator
> ProjNatOriginLatGeoKey: 0.000000 ( 0d 0' 0.00"N)
> ProjNatOriginLongGeoKey: 9.000000 ( 9d 0' 0.00"E)
> ProjScaleAtNatOriginGeoKey: 0.999600
> ProjFalseEastingGeoKey: 500000.000000 m
> ProjFalseNorthingGeoKey: 0.000000 m
> Datum: 6258/European Terrestrial Reference System 1989
> Ellipsoid: 7019/GRS 1980 (6378137.00,6356752.31)
> Projection Linear Units: 9001/metre (1.000000m)
> Corner Coordinates:
> Upper Left ( 417585.000, 6784515.000) ( 7d28' 1.67"E, 61d11'11.02"N)
> Lower Left ( 417585.000, 6538485.000) ( 7d33'58.86"E, 58d58'40.77"N)
> Upper Right ( 660915.000, 6784515.000) ( 11d59'28.13"E, 61d 9'43.28"N)
> Lower Right ( 660915.000, 6538485.000) ( 11d47'51.98"E, 58d57'20.48"N)
> Center ( 539250.000, 6661500.000) ( 9d42'20.11"E, 60d 5'19.35"N)
> -----Original Message-----
> From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Even
> Rouault
Sent: 27. mai 2016 14:28
> To: gdal-dev at lists.osgeo.org
> Cc: Jukka Rahkonen <jukka.rahkonen at maanmittauslaitos.fi>
> Subject: Re: [gdal-dev] EPSG code not recognized from GeoTiff written by
> GDAL
> On Friday 27 May 2016 11:46:14 Jukka Rahkonen wrote:
> > Blumentrath, Stefan <Stefan.Blumentrath <at> nina.no> writes:
> > > Hei,
> > > We are facing issues with GeoTiffs that were written by GDAL, after
> > importing them to GeoServer or opening in Desktop GIS.
> > > On file was produced in GRASS and exported using r.out.gdal (GDAL
> > > 2.1dev),
> > the other file in R, using rgdal (GDAL2.0.x) with EPSG code 25832.
> > > The rasters seem to miss the AUTHORITY parameter...
> > > QGIS for example detects EPSG 3044 (which is technically identical),
> > > and
> > GeoServer considers the CRS as invalid (because of this:
> > http://docs.geonode.org/en/master/tutorials/advanced/geonode_productio
> > n/adv_
> > gsconfig/crs_handling.html).
> > > Did anyone else experience the same?
> > Hi,
> > From my GDAL 2.1-dev
> > gdalsrsinfo epsg:25832
> > PROJ.4 : '+proj=utm +zone=32 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0
> > +units=m
> > +no_de fs '
> > OGC WKT :
> > GEOGCS["ETRS89",
> > UNIT["metre",1,
> > Do you get the same result? If you do I wonder why AUTHORITY is not
> > written into GeoTIFF.
> For diagnosing, what is interesting is the output of the listgeo utility
> that comes with libgeotiff.
Theoretically the EPSG code should be
> preserved in the geotiff keys if it is available in the source raster
> (gdal_translate use case), or if set with the SetProjection() API. I'm not
> sure about GRASS or R but perhaps they build the GDAL SRS object from a
> proj.4 string, in which case the EPSG code will be missing.
> > -Jukka Rahkonen-
> > > Kind regards,
> > > Stefan
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Spatialys - Geospatial professional services http://www.spatialys.com
