[gdal-dev] gdal on freebsd
kit at hypostasis.com kit at hypostasis.com
Mon Nov 7 15:10:27 PST 2016
cd /usr/ports/graphics/gdal
make config
[select the options that you want]
make install clean
should do the trick
it appears that PostGIS Vector is not part of the default package, but
is in the port as an option
  # ogrinfo --formats | grep -i post
   PostgreSQL -vector- (rw+): PostgreSQL/PostGIS
   PGDUMP -vector- (w+v): PostgreSQL SQL dump
On 2016-11-07 00:33, Jyrki Von Karkki wrote:
> Hi all
> I'm having a bit of an issue with the postgresql/postgis driver on
> freebsd. It simply does not appear installed.
> $ ogrinfo --formats | grep -i post
> But on my (linux) desktop for instance it does appear:
> $ ogrinfo --formats | ag post
> Google has been not very helpful so far.
> I was wondering if anyone here might know something?
> Any help appreciated
> Thanks!
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
