[gdal-dev] gdal on freebsd
Jyrki Von Karkki
jyrki_von_karkki at mailbox.org
Mon Nov 7 23:24:05 PST 2016
Thank you both
That will work :)
On 08/11/16 00:10, kit at hypostasis.com wrote:
> cd /usr/ports/graphics/gdal
> make config
> [select the options that you want]
> make install clean
> should do the trick
> it appears that PostGIS Vector is not part of the default package, but
> is in the port as an option
> # ogrinfo --formats | grep -i post
> PostgreSQL -vector- (rw+): PostgreSQL/PostGIS
> PGDUMP -vector- (w+v): PostgreSQL SQL dump
> On 2016-11-07 00:33, Jyrki Von Karkki wrote:
>> Hi all
>> I'm having a bit of an issue with the postgresql/postgis driver on
>> freebsd. It simply does not appear installed.
>> $ ogrinfo --formats | grep -i post
>> But on my (linux) desktop for instance it does appear:
>> $ ogrinfo --formats | ag post
>> Google has been not very helpful so far.
>> I was wondering if anyone here might know something?
>> Any help appreciated
>> Thanks!
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
