[gdal-dev] CAD (DWG) Driver
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sat Nov 19 07:42:29 PST 2016
On 2016-11-19 9:52 AM, Dmitry Baryshnikov wrote:
> Hi,
> I fixed all reported by Even and Kurt errors and recommendations in CAD
> (DWG) driver and most of recommendations in OpenCAD library. The pull
> request (https://github.com/OSGeo/gdal/pull/164) passed all the checks
> successful. It seems to me the driver is ready to merge to the trunk.
> This will simplify testing and reviewing the new driver by community.
> There are some problems in big_endian and xcode CI tests, because of
> C++11 compiler flags (not a problem of CAD driver code, etc.) - I
> disable C++11 (and appropriate the CAD driver too) in this tests. It
> seems to me that not blocking issue and I can merge the code to trunk.
> Are there any objections?
> Just a note: the OpenCAD library and GDAL CAD driver were developed
> during Google Summer of Code 2016.
Could you also be sure to document this driver (and its build steps for
unix and windows) at https://trac.osgeo.org/gdal/wiki/BuildHints ? You
could list your driver there with the others in the section "External
Library Issues"
Thanks!
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
