[gdal-dev] CAD (DWG) Driver
Dmitry Baryshnikov
bishop.dev at gmail.com
Sat Nov 19 11:22:13 PST 2016
I commented out the C++11 mutex in gdaldrivermanager.cpp
<https://github.com/OSGeo/gdal/pull/164/commits/d1449e2eb5a85a6ec2520ad77ee579015fe14197#diff-e3e90e0089f1b70ddf36ebe89a73a733>
- this helps. OSX CI test passed successfully.
https://travis-ci.org/OSGeo/gdal/jobs/177297023
Best regards,
Dmitry
19.11.16 21:24, Even Rouault пишет:
> On samedi 19 novembre 2016 10:06:26 CET Kurt Schwehr wrote:
>> I'm really not sure.
> Not sure that the crash mentionned by Dmitry is related to that ? It looks
> like a really good canditate to me. That's the only C++11 mutex in GDAL, with
> 2 other ones in the GeoTIFF driver (and those are likely not triggered at
> process termination)
>> You can certainly try removing that C++11 mutex. It was added based on the
>> comment at that point in the code. We'll just have to keep an eye out for
>> possible occasional flakes. If that's the case, we'll need to carefully
>> work through the logic and try to figure out a solution that works for
>> everything.
> I doubt we will see flakes related to that. The mutex was added to prevent
> races in GDALDestroyDriverManager(), but I'm not aware of code in GDAL and its
> utilities that would call it from several threads. And the function has always
> been documented as thread-unsafe.
>> +1 for getting the driver into the tree. It will be easier to make
>> additional changes to either it or GDAL with it in the same tree.
>> On Sat, Nov 19, 2016 at 8:49 AM, Even Rouault <even.rouault at spatialys.com>
>> wrote:
>>> On samedi 19 novembre 2016 19:34:02 CET Dmitry Baryshnikov wrote:
>>>> Hi Even,
>>>> The big_endian test now is ok. But osx crash at the exiting of python
>>>> after all test finished successfully.
>>>> This is error message:
>>>> libc++abi.dylib: terminating with uncaught exception of type
>>>> std::__1::system_error: mutex lock failed: Invalid argument
>>>> ./gdal/ci/travis/osx/script.sh: line 13: 56363 Abort trap: 6
>>>> python run_all.py
>>>> I find out that this may be the result of resources free order:
>>>> https://github.com/dmlc/mxnet/issues/309
>>>> https://github.com/google/benchmark/issues/52
>>>> No idea why this occurred then C++11 used. I'll try to use osx CI test
>>>> disabling the CAD driver to exclude this possible issue.
>>> Hum, I think this might be indeed an issue with resource free order
>>> between
>>> the GDALDestroy() destructor function (in gcore/gdaldllmain.cpp) and the
>>> static C++11 mutex Kurt introduced in
>>> https://github.com/OSGeo/gdal/commit/a9b947d6850d496f09e668f4cd1488
>>> 26d45d9fa9
>>> If this mutex gets destroyed before GDALDestroy() is called, then things
>>> might
>>> indeed crash.
>>> I think we should remove this static C++11 mutex. Kurt ?
>>> (Another option would be to remove the library destructor function. I've
>>> the
>>> feeling they cause more harm than good.)
>>> Spatialys - Geospatial professional services
>>> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161119/78087c6b/attachment.html>
