[gdal-dev] ogr2ogr PG->SHP lacks EPSG code
Even Rouault even.rouault at spatialys.com
Sat Nov 19 07:48:30 PST 2016
On samedi 19 novembre 2016 16:34:16 CET Martin Landa wrote:
> Hi,
> 2016-11-13 13:29 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
> thanks for detailed insight. BTW, ogr2ogr couldn't also generates .qpj
> when srs epgs code is given?
It could certainly do this, but the question is more: should it do it ? Adding
another file in addition to the already many ones generated doesn't sound very
appealing. And then on the reading side, you'd have the question of which of
.qpj and .prj is prioritary (I guess .qpj would be prioritary)?
For something completely unrelated, I've a bit improved the reading of .prj
file as GDAL SRS by calling AutoIdentifyEPSG() ( http://www.gdal.org/
classOGRSpatialReference.html#acb0373c83927bfd694048da6f79e33ea ), which can
help retrieving the EPSG code for the most common SRS (very few ones, don't be
too enthousiastic!)
Anyway while looking at that, I saw a mention in the code to https://
trac.osgeo.org/gdal/ticket/6485, which mentions .prj files with EPSG codes in
them. I'm not sure what has generated those .prj files, but I'm wondering what
would be the consequence of OGR keeping the EPSG code in a .prj file (while
still "morphing" SRS names, datum names, projection names and projection
parameters like we do). Would ESRI software (and others) choke on that ?
Even
http://www.spatialys.com
