[gdal-dev] Troubleshooting palette management. Potential bug in palette for overviews?
Daniele Romagnoli
daniele.romagnoli at geo-solutions.it
Thu Nov 24 08:22:50 PST 2016
On Thu, Nov 24, 2016 at 5:01 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 24 novembre 2016 16:51:59 CET Daniele Romagnoli wrote:
> > Doh!
> > Thanks for the feedback, Even.
> (Indeed it seemed strange to me that nobody had ever noticed before)
Sorry, what I meant with that was that I didn't see that ticket before
sending my email so it seemed strange to me that nobody noticed the palette
math weirdness :)
> Not that much regarding software using GDAL since if you don't explicitly
> request the overview bands/datasets but rather use the subsampling
> RasterIO() calls, you'll never work directly with the color table of the
> overviews but still use the one of the main dataset (or even if you request
> the overviews directly I guess in most cases applications don't bother
> checking if the color table of the overview).
As far as I can see, the TIFFImageReader parses the metadata information
based on imageIndex (so overview number). I will double check if things
were working differently in the colormap topic before our
changes/optimizations to this class.
> In GDAL, overviews conceptually share the same palette than the main
> image. Otherwise subsampling RasterIO() will return values of the overview
> palette that will be interpreted with the palette of the main image. You
> can imagine the fun visual effects if the palette are not the same... So
> this is assumed, but not checked.
> Could be worth fixing that if that cause issues (apparently in your use
> case at least), but I'd be interested by information of what is the
> standard/recommanded/best-practice-in-the-industry/etc... formulas to use
> for the mapping between the [0,255] and [0,65535] ranges.
Cheers,
Daniele
> > Best Regards,
> > Daniele
> > On Thu, Nov 24, 2016 at 1:35 PM, Even Rouault <
> > wrote:
> > > Daniele,
> > > This is indeed an inconsistency I spotted a long time ago :
> > > https://trac.osgeo.org/gdal/ticket/2213
> > > Nobody was apparently sufficiently annoyed by this to fix it. Actually
> I
> > > see I proposed a patch. Was probably waiting for feedback. I'm not
> sure if
> > > there's a standardized way of converting between the [0,255] and
> [0,65535]
> > > ranges.
> > > Even
> > > > Hi List,
> > > > I'm investigating on a issue I have with a paletted image with
> > > > overviews,
> > > > using java ImageIO tiff reader (wait... I know on this list we
> discuss
> > > > about GDAL topics :) ).
> > > > I'm trying to better understand palette interpretation and palette
> > > storing
> > > > on tags and how they are handled by GDAL.
> > > > From TIFF specifications, colormap entries are stored as short
> values.
> > > > I have a sample file with this color tab (as reported by gdalinfo).
> > > > Color Table (RGB with 256 entries)
> > > > 0: *164*,164,164,255
> > > > 1: *255*,255,255,255
> > > > 2: 0,0,0,255
> > > > 3: 0,0,0,255
> > > > .... repeat 0,0,0,255 to the end.
> > > > Using an Hex editor or AsTiffTagViewer, I can see the byte values of
> the
> > > > colormap as stored on the file.
> > > > For the first 4 mappings of the colortable the Red components are:
> > > > *A4 A4* *FF FF* 00 00 00 00
> > > > (8 bytes = 4 shorts)
> > > > As far as I have understood, this is related to that part of the
> > > > specification (quoting it, section 5):
> > > > *In a TIFF ColorMap, all the Red values come first, followed by the
> > > > Green
> > > > values, then the Blue values. In the ColorMap, black is represented
> by
> > > > 0,0,0 and white is represented by 65535, 65535, 65535*
> > > > So the second entry of the map, being white (255, 255, 255) has its
> red
> > > > value stored as 65535 = *FF FF *whilst the first color (164,164,164)
> has
> > > > its red value stored as 42148 = *A4 A4*
> > > > I see this behavior is confirmed by the way the geotiff.cpp create
> the
> > > > colortable:
> > > > https://github.com/OSGeo/gdal/blob/trunk/gdal/frmts/gtiff/
> > > geotiff.cpp#L5043
> > > > panTRed[iColor] = static_cast<unsigned short>(257 * sRGB.c1);
> > > > panTGreen[iColor] = static_cast<unsigned short>(257 * sRGB.c2);
> > > > panTBlue[iColor] = static_cast<unsigned short>(257 * sRGB.c3)
> > > > Applying a color*257 multiplication allows to have its 8 bits color
> > > > representation stored into a short where intensity goes from 0 to
> 65535.
> > > > The issue I have is that when using gdaladdo, the overviews are
> > > > generated
> > > > with a different color table.
> > > > So that the first 8 bytes of the red component stored in the
> colormap,as
> > > > reported by AsTiffTagViewer are:
> > > > *A4* 00 *FF* 00 00 00 00 00
> > > > When converting it back to a 0-255 color component with the formula
> > > > R*255/65535 it become *163* instead of 164.
> > > > I see in the GDAL code that both the IBuildOverviews and
> > > > CreateOverviewsFromSrcOverviews call the CreateTIFFColorTable
> function
> > > > which multiplies the colorMapEntry by 256 instead of 257.
> > > geotiff.cpp#L9137
> > > > This may explain the *A4* 00 *FF* 00 entries in the overview with
> > > > respect
> > > > to the *A4 A4 FF FF *entries in the main level.
> > > > Do you have any feedback on this?
> > > > Please, let me know what do you think about it.
> > > > Best Regards,
> > > > Daniele
> > > Spatialys - Geospatial professional services
> > > http://www.spatialys.com
> > > _______________________________________________
> > > gdal-dev mailing list
> > > gdal-dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161124/6e1a6f73/attachment-0001.html>
