[gdal-dev] Troubleshooting palette management. Potential bug in palette for overviews?
Daniele Romagnoli
daniele.romagnoli at geo-solutions.it
Fri Nov 25 02:06:08 PST 2016
For future references (...mainly for me), I'm updating the previous links
using a tagged version.
Otherwise, the line numbers referring a trunk repository will point to some
comment or unrelated things :)
https://github.com/OSGeo/gdal/blob/tags/2.1.2/gdal/frmts/gtiff/geotiff.cpp#L4565
https://github.com/OSGeo/gdal/blob/tags/2.1.2/gdal/frmts/gtiff/geotiff.cpp#L8014
https://github.com/OSGeo/gdal/blob/tags/2.1.2/gdal/frmts/gtiff/geotiff.cpp#L8367
Daniele
On Thu, Nov 24, 2016 at 5:22 PM, Daniele Romagnoli <
daniele.romagnoli at geo-solutions.it> wrote:
> On Thu, Nov 24, 2016 at 5:01 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> On jeudi 24 novembre 2016 16:51:59 CET Daniele Romagnoli wrote:
>> > Doh!
>> > Thanks for the feedback, Even.
>> (Indeed it seemed strange to me that nobody had ever noticed before)
> Sorry, what I meant with that was that I didn't see that ticket before
> sending my email so it seemed strange to me that nobody noticed the palette
> math weirdness :)
>> Not that much regarding software using GDAL since if you don't explicitly
>> request the overview bands/datasets but rather use the subsampling
>> RasterIO() calls, you'll never work directly with the color table of the
>> overviews but still use the one of the main dataset (or even if you request
>> the overviews directly I guess in most cases applications don't bother
>> checking if the color table of the overview).
> As far as I can see, the TIFFImageReader parses the metadata information
> based on imageIndex (so overview number). I will double check if things
> were working differently in the colormap topic before our
> changes/optimizations to this class.
>> In GDAL, overviews conceptually share the same palette than the main
>> image. Otherwise subsampling RasterIO() will return values of the overview
>> palette that will be interpreted with the palette of the main image. You
>> can imagine the fun visual effects if the palette are not the same... So
>> this is assumed, but not checked.
>> Could be worth fixing that if that cause issues (apparently in your use
>> case at least), but I'd be interested by information of what is the
>> standard/recommanded/best-practice-in-the-industry/etc... formulas to
>> use for the mapping between the [0,255] and [0,65535] ranges.
> Cheers,
> Daniele
>> > Best Regards,
>> > Daniele
>> > On Thu, Nov 24, 2016 at 1:35 PM, Even Rouault <
>> > wrote:
>> > > Daniele,
>> > > This is indeed an inconsistency I spotted a long time ago :
>> > > https://trac.osgeo.org/gdal/ticket/2213
>> > > Nobody was apparently sufficiently annoyed by this to fix it.
>> Actually I
>> > > see I proposed a patch. Was probably waiting for feedback. I'm not
>> sure if
>> > > there's a standardized way of converting between the [0,255] and
>> [0,65535]
>> > > ranges.
>> > > Even
>> > > > Hi List,
>> > > > I'm investigating on a issue I have with a paletted image with
>> > > > overviews,
>> > > > using java ImageIO tiff reader (wait... I know on this list we
>> discuss
>> > > > about GDAL topics :) ).
>> > > > I'm trying to better understand palette interpretation and palette
>> > > storing
>> > > > on tags and how they are handled by GDAL.
>> > > > From TIFF specifications, colormap entries are stored as short
>> values.
>> > > > I have a sample file with this color tab (as reported by gdalinfo).
>> > > > Color Table (RGB with 256 entries)
>> > > > 0: *164*,164,164,255
>> > > > 1: *255*,255,255,255
>> > > > 2: 0,0,0,255
>> > > > 3: 0,0,0,255
>> > > > .... repeat 0,0,0,255 to the end.
>> > > > Using an Hex editor or AsTiffTagViewer, I can see the byte values
>> of the
>> > > > colormap as stored on the file.
>> > > > For the first 4 mappings of the colortable the Red components are:
>> > > > *A4 A4* *FF FF* 00 00 00 00
>> > > > (8 bytes = 4 shorts)
>> > > > As far as I have understood, this is related to that part of the
>> > > > specification (quoting it, section 5):
>> > > > *In a TIFF ColorMap, all the Red values come first, followed by the
>> > > > Green
>> > > > values, then the Blue values. In the ColorMap, black is represented
>> by
>> > > > 0,0,0 and white is represented by 65535, 65535, 65535*
>> > > > So the second entry of the map, being white (255, 255, 255) has its
>> red
>> > > > value stored as 65535 = *FF FF *whilst the first color
>> (164,164,164) has
>> > > > its red value stored as 42148 = *A4 A4*
>> > > > I see this behavior is confirmed by the way the geotiff.cpp create
>> the
>> > > > colortable:
>> > > > https://github.com/OSGeo/gdal/blob/trunk/gdal/frmts/gtiff/
>> > > geotiff.cpp#L5043
>> > > > panTRed[iColor] = static_cast<unsigned short>(257 * sRGB.c1);
>> > > > panTGreen[iColor] = static_cast<unsigned short>(257 * sRGB.c2);
>> > > > panTBlue[iColor] = static_cast<unsigned short>(257 * sRGB.c3)
>> > > > Applying a color*257 multiplication allows to have its 8 bits color
>> > > > representation stored into a short where intensity goes from 0 to
>> 65535.
>> > > > The issue I have is that when using gdaladdo, the overviews are
>> > > > generated
>> > > > with a different color table.
>> > > > So that the first 8 bytes of the red component stored in the
>> colormap,as
>> > > > reported by AsTiffTagViewer are:
>> > > > *A4* 00 *FF* 00 00 00 00 00
>> > > > When converting it back to a 0-255 color component with the formula
>> > > > R*255/65535 it become *163* instead of 164.
>> > > > I see in the GDAL code that both the IBuildOverviews and
>> > > > CreateOverviewsFromSrcOverviews call the CreateTIFFColorTable
>> function
>> > > > which multiplies the colorMapEntry by 256 instead of 257.
>> > > geotiff.cpp#L9137
>> > > > This may explain the *A4* 00 *FF* 00 entries in the overview with
>> > > > respect
>> > > > to the *A4 A4 FF FF *entries in the main level.
>> > > > Do you have any feedback on this?
>> > > > Please, let me know what do you think about it.
>> > > > Best Regards,
>> > > > Daniele
>> > > Spatialys - Geospatial professional services
>> > > http://www.spatialys.com
>> > > _______________________________________________
>> > > gdal-dev mailing list
>> > > gdal-dev at lists.osgeo.org
>> > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Daniele Romagnoli
> Senior Software Engineer
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
GeoSolutions S.A.S.
Italy
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161125/9deee5b7/attachment-0001.html>
