[gdal-dev] ReadRaster C# Incorrect values
mvscheers
menno at huss.nl
Tue Oct 18 06:23:28 PDT 2016
Thanks for the suggestion,
I posted a wrong example (Tried everything, converting bytes to doubles etc)
I have tried reading float64 -> c# double. same problem.
Doing this in c++ yields the same result.
Viewing this grib file in panoply gives correct results.
Still at a loss here
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-ReadRaster-C-Incorrect-values-tp5291259p5291263.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
