[gdal-dev] ReadRaster C# Incorrect values
Even Rouault
even.rouault at spatialys.com
Tue Oct 18 06:26:56 PDT 2016
Le mardi 18 octobre 2016 15:23:28, mvscheers a écrit :
> Thanks for the suggestion,
> I posted a wrong example (Tried everything, converting bytes to doubles
> etc) I have tried reading float64 -> c# double. same problem.
> Doing this in c++ yields the same result.
> Viewing this grib file in panoply gives correct results.
> Still at a loss here
I hadn't seen you attached the file. gdalinfo -stats also confirm your findings.
This is probably a defect in the g2clib/degrib libraries used by GDAL to
decode GRIB files.
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-ReadRaster-C-Incorrect-values
> -tp5291259p5291263.html Sent from the GDAL - Dev mailing list archive at
> Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
