[gdal-dev] "dialect SQLITE" isn't working as expected in ogr2ogr
Nelson A. de Oliveira naoliv at gmail.com
Wed Oct 26 05:34:15 PDT 2016
On Wed, Oct 26, 2016 at 8:51 AM, Even Rouault
<even.rouault at spatialys.com> wrote:
> Yes, you didn't explicitly select the geometry field, hence a geometry-less DBF
> is produced. This is indeed a difference in behaviour between OGR SQL (where
> geometry selection is implicit) and the SQLite dialect (where it must be
> explicit, conforming to other spatial enabled SQL databases).
> See the "Geometry field" section in http://www.gdal.org/ogr_sql_sqlite.html
Good.
Thanks!
