[gdal-dev] gdal.RasterizeOptions output type
Even Rouault even.rouault at spatialys.com
Mon Oct 31 03:29:27 PDT 2016
Le lundi 31 octobre 2016 11:11:44, Johan de Braak a écrit :
> Hi all,
> I cannot seem to find the possibility to set the output type in
> gdal.RasterizeOptions (like in gdal.TranslateOptions). Am I missing
> something or is this not possible?
This was indeed a shortcoming. I've just added it in trunk.
You can workaround by using the option string: options="-ot ..."
> I'm using GDAL 2.1.1
> Thank you,
> Johan
> http://osgeo-org.1560.x6.nabble.com/gdal-RasterizeOptions-output-type-tp52
> 93573.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
