[gdal-dev] gdal.RasterizeOptions output type
Ivan Lucena lucena_ivan at hotmail.com
Mon Oct 31 06:24:44 PDT 2016
Even, Are you planning to backport that?
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Even Rouault <even.rouault at spatialys.com>
Sent: Monday, October 31, 2016 6:29:27 AM
To: gdal-dev at lists.osgeo.org
Cc: Johan de Braak
Subject: Re: [gdal-dev] gdal.RasterizeOptions output type
Le lundi 31 octobre 2016 11:11:44, Johan de Braak a écrit :
> Hi all,
> I cannot seem to find the possibility to set the output type in
> gdal.RasterizeOptions (like in gdal.TranslateOptions). Am I missing
> something or is this not possible?
This was indeed a shortcoming. I've just added it in trunk.
You can workaround by using the option string: options="-ot ..."
> I'm using GDAL 2.1.1
> Thank you,
> Johan
> http://osgeo-org.1560.x6.nabble.com/gdal-RasterizeOptions-output-type-tp52
> 93573.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161031/1a6ad663/attachment.html>
