[gdal-dev] gdal.RasterizeOptions output type
Even Rouault
even.rouault at spatialys.com
Mon Oct 31 08:32:30 PDT 2016
Le lundi 31 octobre 2016 14:24:44, Ivan Lucena a écrit :
> Even, Are you planning to backport that?
Done per https://trac.osgeo.org/gdal/ticket/6710
> ________________________________
> From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Even Rouault
> <even.rouault at spatialys.com> Sent: Monday, October 31, 2016 6:29:27 AM
> To: gdal-dev at lists.osgeo.org
> Cc: Johan de Braak
> Subject: Re: [gdal-dev] gdal.RasterizeOptions output type
> Le lundi 31 octobre 2016 11:11:44, Johan de Braak a écrit :
> > Hi all,
> > I cannot seem to find the possibility to set the output type in
> > gdal.RasterizeOptions (like in gdal.TranslateOptions). Am I missing
> > something or is this not possible?
> This was indeed a shortcoming. I've just added it in trunk.
> You can workaround by using the option string: options="-ot ..."
> > I'm using GDAL 2.1.1
> > Thank you,
> > Johan
> > View this message in context:
> > http://osgeo-org.1560.x6.nabble.com/gdal-RasterizeOptions-output-type-tp5
> > 2 93573.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Spatialys - Geospatial professional services
> http://www.spatialys.com
