[gdal-dev] gdal configuration parameters settings...
Even Rouault even.rouault at spatialys.com
Mon Sep 5 02:51:32 PDT 2016
Le lundi 05 septembre 2016 06:56:58, Ari Jolma a écrit :
> 05.09.2016, 03:27, JIA Pei kirjoitti:
> > If I just move forward without enabling all other configurations,
> > namely, still keep all "no"s, and do "make -j8", I got the following
> > error message:
> > libtool: compile: g++ -DHAVE_AVX_AT_COMPILE_TIME
> > -DHAVE_SSSE3_AT_COMPILE_TIME -DHAVE_SSE_AT_COMPILE_TIME -g -O2 -Wall
> > -Wextra -Winit-self -Wunused-parameter -Wformat
> > -Werror=format-security -Wno-format-nonliteral -Wlogical-op -Wshadow
> > -Werror=vla -Wfloat-conversion -Wmissing-declarations
> > -Wnon-virtual-dtor -Woverloaded-virtual -fno-operator-names
> > -I/home/jiapei/Downloads/rsgis/OSGeo/gdal/gdal/port -DGDAL_COMPILATION
> > -c -I../../port Huffman.cpp -o ../../o/Huffman.o >/dev/null 2>&1
> What you don't get it is the error message. Could you run just this
> command without the trailing >/dev/null, which eats the error message?
You probably don't need to do something particular regarding >/dev/null, as
the error message from the compiler should probably be a few lines around in
the console in the non-libtool compilation step.
I've tried to reproduce with an as close possible setup (Ubuntu 16.04.1 + gcc
(Ubuntu 5.4.0-6ubuntu1~16.04.2) 5.4.0 20160609 + today trunk) and this
compiles fine for me.
Even
http://www.spatialys.com
