[gdal-dev] Troubles with VS2015
Joaquim Luis
jluis at ualg.pt
Wed Sep 14 08:23:17 PDT 2016
Thanks Even,
No I hadn't and was reading that MSDN page trying to figure out what to do
with that info.
The build is running now
> Joaquim,
>> odbccp32.lib(dllload.obj) : error LNK2019: unresolved external symbol
>> _vsnwprintf_s referenced in function StringCchPrintfW
>> gdal_w64.dll : fatal error LNK1120: 1 unresolved externals
>> NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual
>> Studio 14.0\VC\BIN\amd64\link.EXE"' : return code '0x460'
>> but odbccp32.lib is a 'system' lib. Any idea on what this is?
>> BTW, it still builds fine with VS2013
> Did you specify MSVC_VER=1900 in the nmake command line ?
> See this extract of nmake.opt:
> !IFDEF ODBC_SUPPORTED
> !IF $(MSVC_VER) >= 1900
> # legacy_stdio_definitions.lib :
> https://connect.microsoft.com/VisualStudio/feedback/details/1134693/vs-2015-
> ctp-5-c-vsnwprintf-s-and-other-functions-are-not-exported-in-appcrt140-dll-
> breaking-linkage-of-static-libraries
> ODBCLIB = legacy_stdio_definitions.lib odbc32.lib odbccp32.lib user32.lib
> !ELSE
> ODBCLIB = odbc32.lib odbccp32.lib user32.lib
> !ENDIF
> !ENDIF
> Even
