[gdal-dev] SQLite driver?
Even Rouault
even.rouault at spatialys.com
Wed Sep 14 10:46:14 PDT 2016
Le mercredi 14 septembre 2016 19:43:22, Joaquim Luis a écrit :
> Sorry, my bad. When I thought I was using gisinternals I was actually
> using my build. Gisinternals does show the SQLite driver.
> But one of my points still holds. If the Walker shows me that sqlite3.dll
> is a dependency than why the SQLite driver is not available?
You mentionned that you "(re)build" GDAL with sqlite, so I assume you added it
after a first build. So I suspect that some files didn't get recompiled. The
safest way if not already done is to clean and rebuild.
Otherwise, mostly for a quick check, you may just 'touch'
ogr/ogrsf_frmts/generic/ogrregisterall.cpp but you'll probably miss a few files
that will benefit from sqlite being now available. So the clean & rebuild path
is the safest ultimately.
> > Hmm, several (weird) things.
> > 1. I'm using GnuWin ports for unix commands. And:
> > - this works
> > gdalinfo --formats | sort
> > - this not (output is empty)
> > ogfinfo --formats | sort
> > Same thing for 'grep'
> > 2. To check I'm using gisinternals and same thing as my build.
> > ogrinfo --formats shows no SQLite driver
> > 3. The program I'm trying to build/run crashes at this line
> > https://github.com/osmcode/osmcoastline/blob/master/include/gdalcpp.hp
> > p#L132 (no idea why it crashes) apparently because it doesn't find the
> > SQLite driver (driver_name == 'SQLite')
> >> ogrinfo --formats | grep -i lite
> >> SQLite -vector- (rw+v): SQLite / Spatialite
> >> On Wed, Sep 14, 2016 at 9:32 AM, Joaquim Luis <jluis at ualg.pt> wrote:
> >>> Sorry Even that you are bombed with so many questions.
> >>> I have (re)build GDAL with sqlite and can confirm with The
> >>> (Dependency) Walker that the sqlite3.dll is a gdal.dll dependency.
> >>> However,
> >>> gdalinfo --formats
> >>> Rasterlite -raster- (rws): Rasterlite
> >>> SAFE -raster- (rov): Sentinel-1 SAR SAFE Product
> >>> SAR_CEOS -raster- (rov): CEOS SAR Image
> >>> SDTS -raster- (rov): SDTS Raster
> >>> SENTINEL2 -raster- (rovs): Sentinel 2
> >>> SGI -raster- (rw+): SGI Image File Format 1.0
> >>> SRTMHGT -raster- (rwv): SRTMHGT File Format
> >>> TIL -raster- (rov): EarthWatch .TIL
> >>> does not show the SQLite driver and indeed a program that I'm building
> >>> that needs to link with GDAL (osmcoastline) crashes when it doesn't
> >>> find >>>that driver.
> >>> Joaquim
> >>> _______________________________________________
> >>> gdal-dev mailing list
> >>> gdal-dev at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> >> http://schwehr.org
http://www.spatialys.com
