[gdal-dev] SQLite driver?
Joaquim Luis
jluis at ualg.pt
Wed Sep 14 11:31:16 PDT 2016
OK, clean & rebuilt (as I (thought) did before) and I can see the SQLite
driver now.
However, the osmcoastline still crashes. Unfortunately, it's too damn C++
for me to debugg.
> Le mercredi 14 septembre 2016 19:43:22, Joaquim Luis a écrit :
>> Sorry, my bad. When I thought I was using gisinternals I was actually
>> using my build. Gisinternals does show the SQLite driver.
>> But one of my points still holds. If the Walker shows me that
>> sqlite3.dll
>> is a dependency than why the SQLite driver is not available?
> You mentionned that you "(re)build" GDAL with sqlite, so I assume you
> added it
> after a first build. So I suspect that some files didn't get recompiled.
> The
> safest way if not already done is to clean and rebuild.
> Otherwise, mostly for a quick check, you may just 'touch'
> ogr/ogrsf_frmts/generic/ogrregisterall.cpp but you'll probably miss a
> few files
> that will benefit from sqlite being now available. So the clean &
> rebuild path
> is the safest ultimately.
>> > Hmm, several (weird) things.
>> > 1. I'm using GnuWin ports for unix commands. And:
>> > - this works
>> > gdalinfo --formats | sort
>> > - this not (output is empty)
>> > ogfinfo --formats | sort
>> > Same thing for 'grep'
>> > 2. To check I'm using gisinternals and same thing as my build.
>> > ogrinfo --formats shows no SQLite driver
>> > 3. The program I'm trying to build/run crashes at this line
>> https://github.com/osmcode/osmcoastline/blob/master/include/gdalcpp.hp
>> > p#L132 (no idea why it crashes) apparently because it doesn't find
>> the
>> > SQLite driver (driver_name == 'SQLite')
>> >> ogrinfo --formats | grep -i lite
>> >> SQLite -vector- (rw+v): SQLite / Spatialite
>> >> On Wed, Sep 14, 2016 at 9:32 AM, Joaquim Luis <jluis at ualg.pt> wrote:
>> >>> Sorry Even that you are bombed with so many questions.
>> >>> I have (re)build GDAL with sqlite and can confirm with The
>> >>> (Dependency) Walker that the sqlite3.dll is a gdal.dll dependency.
>> >>> However,
>> >>> gdalinfo --formats
>> >>> Rasterlite -raster- (rws): Rasterlite
>> >>> SAFE -raster- (rov): Sentinel-1 SAR SAFE Product
>> >>> SAR_CEOS -raster- (rov): CEOS SAR Image
>> >>> SDTS -raster- (rov): SDTS Raster
>> >>> SENTINEL2 -raster- (rovs): Sentinel 2
>> >>> SGI -raster- (rw+): SGI Image File Format 1.0
>> >>> SRTMHGT -raster- (rwv): SRTMHGT File Format
>> >>> TIL -raster- (rov): EarthWatch .TIL
>> >>> does not show the SQLite driver and indeed a program that I'm
>> building
>> >>> that needs to link with GDAL (osmcoastline) crashes when it doesn't
>> >>> find >>>that driver.
>> >>> Joaquim
>> >>> _______________________________________________
>> >>> gdal-dev mailing list
>> >>> gdal-dev at lists.osgeo.org
>> >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> >> http://schwehr.org
