[gdal-dev] SQLite driver?
Kurt Schwehr
schwehr at gmail.com
Wed Sep 14 13:02:06 PDT 2016
A stack trace would give others a chance to possibly spot what the crash is.
On Wed, Sep 14, 2016 at 11:31 AM, Joaquim Luis <jluis at ualg.pt> wrote:
> OK, clean & rebuilt (as I (thought) did before) and I can see the SQLite
> driver now.
> However, the osmcoastline still crashes. Unfortunately, it's too damn C++
> for me to debugg.
> Le mercredi 14 septembre 2016 19:43:22, Joaquim Luis a écrit :
>>> Sorry, my bad. When I thought I was using gisinternals I was actually
>>> using my build. Gisinternals does show the SQLite driver.
>>> But one of my points still holds. If the Walker shows me that sqlite3.dll
>>> is a dependency than why the SQLite driver is not available?
>> You mentionned that you "(re)build" GDAL with sqlite, so I assume you
>> added it
>> after a first build. So I suspect that some files didn't get recompiled.
>> The
>> safest way if not already done is to clean and rebuild.
>> Otherwise, mostly for a quick check, you may just 'touch'
>> ogr/ogrsf_frmts/generic/ogrregisterall.cpp but you'll probably miss a
>> few files
>> that will benefit from sqlite being now available. So the clean & rebuild
>> path
>> is the safest ultimately.
>>> > Hmm, several (weird) things.
>>> > 1. I'm using GnuWin ports for unix commands. And:
>>> > - this works
>>> > gdalinfo --formats | sort
>>> > - this not (output is empty)
>>> > ogfinfo --formats | sort
>>> > Same thing for 'grep'
>>> > 2. To check I'm using gisinternals and same thing as my build.
>>> > ogrinfo --formats shows no SQLite driver
>>> > 3. The program I'm trying to build/run crashes at this line
>>> > https://github.com/osmcode/osmcoastline/blob/master/include/
>>> gdalcpp.hp
>>> > p#L132 (no idea why it crashes) apparently because it doesn't find
>>> the
>>> > SQLite driver (driver_name == 'SQLite')
>>> >> ogrinfo --formats | grep -i lite
>>> >> SQLite -vector- (rw+v): SQLite / Spatialite
>>> >> On Wed, Sep 14, 2016 at 9:32 AM, Joaquim Luis <jluis at ualg.pt> wrote:
>>> >>> Sorry Even that you are bombed with so many questions.
>>> >>> I have (re)build GDAL with sqlite and can confirm with The
>>> >>> (Dependency) Walker that the sqlite3.dll is a gdal.dll dependency.
>>> >>> However,
>>> >>> gdalinfo --formats
>>> >>> Rasterlite -raster- (rws): Rasterlite
>>> >>> SAFE -raster- (rov): Sentinel-1 SAR SAFE Product
>>> >>> SAR_CEOS -raster- (rov): CEOS SAR Image
>>> >>> SDTS -raster- (rov): SDTS Raster
>>> >>> SENTINEL2 -raster- (rovs): Sentinel 2
>>> >>> SGI -raster- (rw+): SGI Image File Format 1.0
>>> >>> SRTMHGT -raster- (rwv): SRTMHGT File Format
>>> >>> TIL -raster- (rov): EarthWatch .TIL
>>> >>> does not show the SQLite driver and indeed a program that I'm
>>> building
>>> >>> that needs to link with GDAL (osmcoastline) crashes when it doesn't
>>> >>> find >>>that driver.
>>> >>> Joaquim
>>> >>> _______________________________________________
>>> >>> gdal-dev mailing list
>>> >>> gdal-dev at lists.osgeo.org
>>> >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> >> http://schwehr.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160914/d2afb0cb/attachment-0001.html>
