[gdal-dev] Binary of the latest released GDAL for travis?
Ari Jolma ari.jolma at gmail.com
Tue Apr 11 03:48:35 PDT 2017
11.04.2017, 13:28, Bas Couwenberg kirjoitti:
> On 2017-04-11 12:22, Ari Jolma wrote:
>> 11.04.2017, 13:05, Angelos Tzotsos kirjoitti:
>>> Hi Ari,
>>> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
>>> sudo apt-get update
>>> sudo apt-get install libgdal-dev
>>> This should do it.
>> No. I tried that before (found it in my .travis.yml file...) and it
>> pulls in older version 1.10.0.
> You can install the 2.1.3 version explicitly with:
>  sudo apt-get install libgdal-dev=2.1.3+dfsg-1~xenial2
It seems it did not even try this. Probably because it is precise?
> But this will fail when the version is updated in the PPA.
> Is the travis environment using Ubuntu xenial, and not an older LTS
> like trusty or precise? It's probably trusty since that ships with
> GDAL 1.10.1.
It is precise. Trusty build environment is in beta.
> For those older LTS releases the UbuntuGIS packages haven't been
> updated yet. Depending on manpower and motivation we may be able to
> updated the trusty packages in the near future.
It would save a lot of build time at least for me.
The reason for me is that many of my project use the GDAL Perl bindings
and for the tests I pull in the latest from CPAN, which is based on the
latest released GDAL.
> Ideally the travis environment is upgraded to xenial for which the
> best support is available and the default packages in Ubuntu itself
> are much more current.
ok
Thanks,
Ari
> Kind Regards,
> Bas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
