[gdal-dev] GDAL 2.2.0 beta 1 available
Kurt Schwehr
schwehr at gmail.com
Fri Apr 14 07:59:43 PDT 2017
Even,
Thanks for your hard work!
I did a quick mac osx fink build and spot checks with autotest - build
looks good.
A quick check of NEWS:
Kakadu v7.9.1 works for me. The line "add support for Kakadu v7.8" should
probably be something like:
add support for Kakadu v7.9.1. v7.8 should not be used. It has a bug
fixed in v7.9.
Should be 9.0:
OGRSpatialReference:
* Upgrade to EPSG database v8.9 <----- Upgrade to EPSG database v9.0
(#6772)
On Fri, Apr 14, 2017 at 1:10 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> I have prepared the GDAL/OGR 2.2.0 Beta 1 release. It will potentially be
> followed by a second beta, or directly by a RC1 if things go well. The
> source is available at:
> http://download.osgeo.org/gdal/2.2.0/gdal-2.2.0beta1.tar.xz
> http://download.osgeo.org/gdal/2.2.0/gdal-2.2.0beta1.tar.gz
> http://download.osgeo.org/gdal/2.2.0/gdal220beta1.zip
> A snapshot of the Python autotest suite can be downloaded from:
> http://download.osgeo.org/gdal/2.2.0/gdalautotest-2.2.0beta1.tar.gz
> http://download.osgeo.org/gdal/2.2.0/gdalautotest-2.2.0beta1.zip
> The GRASS plugin is available at
> http://download.osgeo.org/gdal/2.2.0/gdal-grass-2.2.0beta1.tar.gz
> The NEWS is available at :
> http://svn.osgeo.org/gdal/branches/2.2/gdal/NEWS
> New bugs found should be filed in Trac normally.
> http://trac.osgeo.org/gdal
> GDAL developers and users are encouraged to treat the next 2 weeks
> as the prime time for bug finding and fixing.
> I have created the GDAL 2.2 branch from current trunk, so new developments
> can occur in trunk. Bug fixes that apply to 2.2 should be committed in both
> trunk and branches/2.2
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170414/503187a3/attachment.html>
