[gdal-dev] GDAL 2.2.0 beta 1 available
Even Rouault
even.rouault at spatialys.com
Fri Apr 14 08:09:58 PDT 2017
On vendredi 14 avril 2017 07:59:43 CEST Kurt Schwehr wrote:
> Even,
> Thanks for your hard work!
> I did a quick mac osx fink build and spot checks with autotest - build
> looks good.
> A quick check of NEWS:
> Kakadu v7.9.1 works for me. The line "add support for Kakadu v7.8" should
> probably be something like:
> add support for Kakadu v7.9.1. v7.8 should not be used. It has a bug
> fixed in v7.9.
> Should be 9.0:
> OGRSpatialReference:
> * Upgrade to EPSG database v8.9 <----- Upgrade to EPSG database v9.0
> (#6772)
I let you commit those changes and any other you may find appropriate? It certainly needs
double checking.
Eve
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170414/022e00c7/attachment.html>
