[gdal-dev] gdalwarp RCP issues between GDAL 2.1.0 and 2.1.3
Deschamps, Benjamin (AAFC/AAC) benjamin.deschamps at canada.ca
Fri Apr 21 09:50:10 PDT 2017
A bit more information:
PROJ4 is 4.8.0 for GDAL 2.1.0; I think GDAL 2.1.3 might be getting the same version, from the system environment variables.
Machine has 32GB RAM.
Benjamin
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: April-21-17 12:29 PM
To: Deschamps, Benjamin (AAFC/AAC)
Cc: Rollin, Patrick (AAFC/AAC)
Subject: Re: [gdal-dev] gdalwarp RCP issues between GDAL 2.1.0 and 2.1.3
> I can make the input files available to specific people via Google Drive,
> please let me know.
That would be useful indeed. Could you also specify the version number of proj.4 ? And the amount of RAM of the machine as well.
Even
> Thanks,
> Benjamin Deschamps
> Physical Sciences Specialist - Geoinformatics, Science and Technology Branch
> Agriculture and Agri-Food Canada / Government of Canada
> Benjamin.Deschamps at canada.ca<mailto:Benjamin.Deschamps at canada.ca> / Tel: 613-715-5130 / TTY: 613-773-2600
> Spécialiste des sciences physiques - Géoinformatique, Direction générale des
> sciences et de la technologie Agriculture et Agroalimentaire Canada /
> Gouvernement du Canada
> Benjamin.Deschamps at canada.ca<mailto:Benjamin.Deschamps at canada.ca> / Tél. : 613-715-5130 / ATS : 613-773-2600
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170421/e7fec961/attachment.html>
