[gdal-dev] gdal2tiles.py of transparent background vrt/png gives black background tiles
Grégory Bataille
gregory.bataille at gmail.com
Sun Apr 23 00:35:53 PDT 2017
Hey John,
Is your TIF transparent background using properly the NODATA special value?
If so you can tell gdal2tiles how to interpret and translate the nodata in
RGBA using the -a option
gdal2tiles.py SOURCE DEST -a 0,0,0,0
I think that should produce the desired effect
Let me know
Gregory Bataille
On Sun, Apr 23, 2017 at 7:55 AM, John W. Glendening <glendening at drjack.net>
wrote:
> I have been creating a tileset from a .vrt based upon .tif files using
> gdal2tiles.py. The .tif files consist of lines overlaid upon a
> background map but I now want to eliminate the background map,
> i.e. make that area transparent, so the tiles will have only the lines
> on a transparent background, so they can be used as an overlay.
> I successfully produced the desired .tif files with transparent
> background and created a .vrt. But using gdal2tiles.py gives a black
> background (RGBA=0,0,0,255) where a transparent background is
> expected. (The expected lines _are_ present, on top of the black
> background.)
> Thinking that there might be a problem with the gdal2tiles.py
> interpretation of the .vrt, I used gdal_translate to convert it to a
> (large!) .png file and used that as the gdal2tiles.py argument
> instead. But the background remains black. As a check of the png
> file, I used gdal_translate to crop out and view a section and its
> background was indeed transparent (RGBA=0,0,0,0) in the expected
> places.
> I also tried two other variants of the gdal2tiles.py file that I found
> on the web, one from osgeo (with a 2013 copyright) and one from a
> geophython site - with identical results.
> I'm hoping for some guidance here.
> FYI an extract of gdalinfo for the .vrt file is:
> Driver: VRT/Virtual Raster
> Files: 24ksections.vrt
> /home/glendeni/HIKES/TRAILMAP/TILES/BigSurTrailmap-
> sectionA1-map.tif
> Size is 37840, 48993
> Coordinate System is:
> PROJCS["unnamed",
> GEOGCS["unnamedellipse",
> DATUM["unknown",
> SPHEROID["unnamed",6378137,0]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Mercator_1SP"],
> PARAMETER["central_meridian",0],
> PARAMETER["scale_factor",1],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]]]
> Origin = (-13565727.275918338447809,4356632.541813874617219)
> Pixel Size = (1.836533043499999,-1.836542168400001)
> Corner Coordinates:
> Upper Left (-13565727.276, 4356632.542) (121d51'46.81"W,
> 36d24'21.64"N)
> Lower Left (-13565727.276, 4266654.831) (121d51'46.81"W, 35d45'
> 9.94"N)
> Upper Right (-13496232.866, 4356632.542) (121d14'19.40"W,
> 36d24'21.64"N)
> Lower Right (-13496232.866, 4266654.831) (121d14'19.40"W, 35d45'
> 9.94"N)
> Center (-13530980.071, 4311643.687) (121d33' 3.10"W, 36d
> 4'48.23"N)
> Band 1 Block=128x128 Type=UInt16, ColorInterp=Red
> Band 2 Block=128x128 Type=UInt16, ColorInterp=Green
> Band 3 Block=128x128 Type=UInt16, ColorInterp=Blue
> Band 4 Block=128x128 Type=UInt16, ColorInterp=Alpha
> The gdalinfo for the .png created by gdal_translate from the .vrt is:
> Driver: PNG/Portable Network Graphics
> Files: 24ksections.png
> 24ksections.png.aux.xml
> PROJCS["unnamed",
> DATUM["unknown",
> UNIT["metre",1,
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> Corner Coordinates:
> 36d24'21.64"N)
> 9.94"N)
> 36d24'21.64"N)
> 9.94"N)
> 4'48.23"N)
> Band 1 Block=37840x1 Type=UInt16, ColorInterp=Red
> Band 2 Block=37840x1 Type=UInt16, ColorInterp=Green
> Band 3 Block=37840x1 Type=UInt16, ColorInterp=Blue
> Band 4 Block=37840x1 Type=UInt16, ColorInterp=Alpha
> John W. (Jack) Glendening
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170423/284e8a36/attachment-0001.html>
