[gdal-dev] GDAL 2.2.0 beta 2 available
Sean Gillies sean at mapbox.com
Tue Apr 25 05:26:46 PDT 2017
Hi Even,
2.2.0beta2 fails to build on my macbook. Here is the error:
cpl_conv.cpp:2060:9: error: use of undeclared identifier 'isnan'; did you
mean 'std::isnan'?
    if( CPLIsNan(dfAngle) )
/Users/sean/code/frs-wheel-builds/parts/gdal__compile__/gdal-2.2.0/port/cpl_port.h:687:23:
note: expanded from macro 'CPLIsNan'
#  define CPLIsNan(x) isnan(x)
/usr/include/c++/4.2.1/cmath:551:5: note: 'std::isnan' declared here
    isnan(_Tp __f) { return ::__gnu_cxx::__capture_isnan(__f); }
1 error generated.
My compiler details:
$ gcc -v
Configured with: --prefix=/Library/Developer/CommandLineTools/usr
--with-gxx-include-dir=/usr/include/c++/4.2.1
Apple LLVM version 8.0.0 (clang-800.0.42.1)
Target: x86_64-apple-darwin16.4.0
Thread model: posix
InstalledDir: /Library/Developer/CommandLineTools/usr/bin
Perhaps related to the changes at
https://github.com/OSGeo/gdal/blame/trunk/gdal/port/cpl_port.h#L656-L667?
2.1.3 builds with no errors, only a few warnings about redefinition of
HAVE_LONG_LONG (in combination with Python).
On Sun, Apr 23, 2017 at 2:58 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> As there have already been a number of changes, I have prepared a Beta 2
> for GDAL/OGR 2.2.0. I think we can still aim for a RC1 at end of the week.
> The source is available at:
> http://download.osgeo.org/gdal/2.2.0/gdal-2.2.0beta2.tar.xz
> http://download.osgeo.org/gdal/2.2.0/gdal-2.2.0beta2.tar.gz
> http://download.osgeo.org/gdal/2.2.0/gdal220beta2.zip
> A snapshot of the Python autotest suite can be downloaded from:
> http://download.osgeo.org/gdal/2.2.0/gdalautotest-2.2.0beta2.tar.gz
> http://download.osgeo.org/gdal/2.2.0/gdalautotest-2.2.0beta2.zip
> Changes since beta1 :
> - GeoJSON: improve/fix field type promotion
> - OGRGeometryFactory::organizePolygons(): return POLYGON EMPTY when -
> nPolygonCount == 0
> - Remove all direct uses of json_tokener_parse_ex(); use OGRJSonParse()
> instead
> - Set string length for libjson parser in OGRJSonParse.
> - GeoJSON: fix crash if NATIVE_MEDIA_TYPE creation option is specified
> alone
> - validate_gpkg: fix validation of req 62
> - Python bindings: accept unicode strings as field name argument in
> Feature (like SetField, GetField, etc...) and FeatureDefn methods
> - javadoc.java: fix signature for get/set datetime methods
> gdalwarp: fix crash when -multi and -to RPC_DEM are used together (fixes
> #6869)
> - NITF: add support for writing JPEG2000 compressed images with
> JP2OpenJPEG driver; fix writing with JP2KAK driver (emit codestream only
> instead of JP2 format); fix setting of NBPR/NBPC/NPPBH/NPPBV fields for
> JPEG2000 (fixes #4322); in JP2ECW case, make sure that the default
> PROFILE=NPJE implies 1024 block size at the NITF level
> - Fix hErrorMutex leak if GDALAllRegister is not called
> - OGRParse: fix parsing logic to avoid false positive detection of string
> as datetime (#6867)
> - GMLAS: improve swe:DataArray support and add swe:DataRecord support
> - PDF: fix compilation with C++11 compiler and Poppler 0.15 from
> CentOS/RHEL 6
> - Add CPLString(const char*, n) constructor (and some cleanup for ancient
> unsupported MSVC versions)
> - GeoRaster driver: support for JP2-F compression, support direct loading
> of - - JPEG-F when blocking=no, default blocking increased from 256x256 to
> 512x512 (#6861)
> - OpenJpeg driver: support direct extracting of GeoRaster JP2-F BLOB
> (#6861)
> - OCI driver: support for long identifiers (up to 128 long) when running
> of 12.2 or + (#6866)
> - OCILOB VSIL driver: new driver to streams in and out of Oracle BLOB as a
> GDAL large virtual file system (#6861)
> - netCDF: fix compilation with VS2015
> - GTX: fix behaviour of SHIFT_ORIGIN_IN_MINUS_180_PLUS_180=YES when
> origin is at -180
> - GTiff: map D_North_American_1927 datum citation name to OGC
> North_American_Datum_1927 so that datum is properly recognized (fixes #6863)
> - MBTiles: fix setting of minzoom when computing overviews out of order
> - Fix runtime of Python VRT derived bands with numpy 1.3 of RHEL 6
> - GPKG: fix compilation error with sqlite3 < 3.7.8
> - OSM: rename constant variable to knPAGE_SIZE to avoid clash with
> Cygwin's #define PAGE_SIZE in /usr/include/limits.h
> - CSV: fix comparison broken in r36979 (fixes #6862)
> - MBTiles: do not open .mbtiles that contain vector tiles, which are not
> supported by the driver
> - netCDF: add a HONOUR_VALID_RANGE=YES/NO open option to control whether
> pixel values outside of the validity range should be set to the nodata
> value (#6857)
> - DTED: correctly create files at latitudes -80, -75, -70 and -50 (#6859)
> - Internal libgeotiff: hide symbols in --with-hide-internal-symbols mode
> - configure: propagate -fvisibility=hidden in --with-hide-internal-symbols
> mode in CFLAGS_NOFTRAPV, CXXFLAGS_NOFTRAPV, CXXFLAGS_NO_LTO_IF_AVX_NONDEFAULT
> and CXXFLAGS_NO_LTO_IF_SSSE3_NONDEFAULT
> - Shape: do not export Shapelib symbols for builds
> --with-hide-internal-symbols (#6860)
> - GPKG: do not change application_id/user_version when appending a raster
> to an existing database
> - GPKG: do not warn on gpkg_schema extension
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170425/2b4666b9/attachment-0001.html>
