[gdal-dev] [Qgis-developer] GDAL 2.2.0 beta 2 available
Even Rouault even.rouault at spatialys.com
Tue Apr 25 02:04:46 PDT 2017
> Hum, there might be an intermediate option: revert the change in GDAL 2.2
> branch, and keep it in 2.3dev which will probably be released in one year,
> at a time where QGIS 3 should have been released to.
I've taken another road finally. Build the internal copy of shapelib of QGIS with some
modifications :
* prefix all the SHP* and DBF* symbols of it with qgis_ to avoid symbol name clashes
* and use GDAL VSI Large file I/O instead of standard lib FILE API so that UTF-8 names are
properly handled on Windows.
>From my (light) tests, seems to work (on Linux).
==> https://github.com/qgis/QGIS/pull/4413
Even
> > Matthias
> > On 4/24/17 7:20 PM, Even Rouault wrote:
> > > Hi,
> > > > - Shape: do not export Shapelib symbols for builds
> > > > --with-hide-internal-symbols (#6860)
> > > It turns out that the above change breaks QGIS 2.18 build, in
> > > particular the DXF2SHP converter native plugin, since it does a nasty
> > > trick: the QGIS build tree has the shapelib 2.10 includes files, but
> > > relies on linking against shapelib symbols exported by libgdal. The
> > > plugin apparently no longer exists in QGIS master, which builds fine
> > > against GDAL 2.2beta2.
> > > So I'm not sure what to do:
> > > 1) revert #6860 and export again shapelib symbols from GDAL. But this
> > > apparently breaks some other workflows
> > > 2) let distributions apply a patch to do this revert, while they use
> > > QGIS 2.18 or other code that depend on GDAL exporting shapelib symbols
> > > 3) Change DXF2SHP plugin to use OGR API instead of shapelib, but I'm
> > > not feeling like I would do that myself.
> > > My opinion would be to favor 2)
> > > Opinions ?
> > > Even
> > > Spatialys - Geospatial professional services
> > > http://www.spatialys.com
> > > _______________________________________________
> > > Qgis-developer mailing list
> > > Qgis-developer at lists.osgeo.org
> > > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170425/809e2ebf/attachment-0001.html>
