[gdal-dev] Wrong namespaces in GML 3.2 written by GDAL
Even Rouault
even.rouault at spatialys.com
Thu Apr 27 10:06:17 PDT 2017
On jeudi 27 avril 2017 17:01:27 CEST Rahkonen Jukka (MML) wrote:
> Hi,
> With GML 3.2 output GDAL 2.2-dev writes into the schema
> xmlns:gml="http://www.opengis.net/gml/3.2"
> xmlns:gmlsf="http://www.opengis.net/gmlsf/2.0"
> The first one redirects to http://schemas.opengis.net/gml/3.2.1/gml.xsd.
> The latter one gives "Not found". I guess that the schema is nowadays in
> http://schemas.opengis.net/gmlsfProfile/2.0/
Jukka,
I think what GDAL writes currently is correct. There's no requirement for a namespace URI to
be HTTP resolvable and point to a schema. This is just a conventional name.
Actually if you look at
http://schemas.opengis.net/gmlsfProfile/2.0/gmlsfLevels.xsd , you can see
Even
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170427/8cbabfe3/attachment.html>
