[gdal-dev] Wrong namespaces in GML 3.2 written by GDAL
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Thu Apr 27 10:10:39 PDT 2017
Hi Evan,
Oh yeah, a few lines later I can read
<xs:import namespace="http://www.opengis.net/gml/3.2" schemaLocation="http://schemas.opengis.net/gml/3.2.1/gml.xsd"/>
<xs:import namespace="http://www.opengis.net/gmlsf/2.0" schemaLocation="http://schemas.opengis.net/gmlsfProfile/2.0/gmlsfLevels.xsd"/>
Sorry for the noise.
-Jukka-
Even Rouault wrote:
Re: [gdal-dev] Wrong namespaces in GML 3.2 written by GDAL
On jeudi 27 avril 2017 17:01:27 CEST Rahkonen Jukka (MML) wrote:
> Hi,
> With GML 3.2 output GDAL 2.2-dev writes into the schema
> xmlns:gml="http://www.opengis.net/gml/3.2"
> xmlns:gmlsf="http://www.opengis.net/gmlsf/2.0"
> The first one redirects to http://schemas.opengis.net/gml/3.2.1/gml.xsd.
> The latter one gives "Not found". I guess that the schema is nowadays in
Jukka,
I think what GDAL writes currently is correct. There's no requirement for a namespace URI to be HTTP resolvable and point to a schema. This is just a conventional name.
Actually if you look at
http://schemas.opengis.net/gmlsfProfile/2.0/gmlsfLevels.xsd , you can see
Even
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170427/acedb579/attachment-0001.html>
