[gdal-dev] Call for discussion on RFC 70: Guessing output format from output file name extension
Even Rouault even.rouault at spatialys.com
Sat Aug 19 13:49:19 PDT 2017
This is a call for discussion on:
https://trac.osgeo.org/gdal/wiki/rfc70_output_format_guess
Summary:
This proposal is to add syntaxic sugar to make GDAL and OGR command line
utilities, so they take into account the extension of the output filename to
guess which output driver to use, when it is not explicitly specified.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170819/bb0ce388/attachment.html>
